It is currently Sat Aug 02, 2025 6:05 pm
PostPosted: Sat Dec 26, 2015 12:04 pm
Hi all,
Got my engine in the other day which has got a nissan pulsar dissy installed. I noticed once the distributor is set up it fouls on my bonnet release handle even with elbow HT leads.
I found this and wondered if anyone had installed on on their round nose, and if so any opinions on it / difficulty to install ect?
http://www.minisport.com/fse10020kit-in ... e-kit.html
It would get rid of the external release which the lead is resting on so thought it might be a good little accessory - depending on modifications required.
Hope everyone had a good Christmas!
James
PostPosted: Sat Dec 26, 2015 3:01 pm
I installed one on my 65 deluxe, more for a little piece of mind as the engine bay cant be accessed from outside of the car, not that it would stop a determined thief! it was simple to fit, no mods required.
Jenk.
PostPosted: Sat Dec 26, 2015 4:42 pm
To Do it properly you will also need to change the Grille to the internal bonnet release type which does not have the big gap to put fingers through.
"Let us remove your "SHORTS"
PostPosted: Sun Dec 27, 2015 7:53 am
Or just rivet/screw a small metal plate behind the opening.... 8)
Cheers, Ian
PostPosted: Sun Dec 27, 2015 1:38 pm
Cheers, Ian
or replace the top slat with one from another grille and cut it to length...
as for the distributor, pull the distributor drive out of the block and turn it around to the next tooth, then it'll be away from the bonnet release and you don't have to change anything
PostPosted: Sun Dec 27, 2015 3:29 pm
I never suggest to anyone to remove the dizzy drive, you know it will end up in the sump. :lol:
Just turn the dizzy a quarter of a turn one way and swap the leads in the cap a quarter of a turn the other way.
PostPosted: Sun Dec 27, 2015 3:56 pm
He did this the other day when he had a Gemini starter on it.
Users browsing this forum: Steam, timmy201 and 95 guests
