It is currently Sat Aug 02, 2025 8:23 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Dec 23, 2015 9:27 pm
Valvoline VR1 is commonly used in Minis in USA.
Check on http://www.minimania.com/msgthreads forum.
PostPosted: Wed Dec 23, 2015 9:38 pm
Thanks doc
PostPosted: Sun Dec 27, 2015 9:44 pm
I picked up a 4 litre bottle on the mark down table at aldi for $7.50 today
I was the premium stuff but so ill get another litre bottle to make it 5 litres next time I'm at a car parts shop
No need to get a litre now picked up another 4 litre bottle at a different aldi store close to me for the same price on that stores mark down table today
PostPosted: Mon Dec 28, 2015 7:41 am
GR wrote:
HI Mini053
I now use the Gulf Western 20w 50 straight from supa cheap :shock:
Graham Russell
I see Supercheap have Gulf Western XP 20W50 @ 50% off at the moment , $7.50 a bottle .
PostPosted: Mon Dec 28, 2015 8:49 am
goodie wrote:
GR wrote:
HI Mini053
Graham Russell
If they can sell it for $7.50 a bottle and still make a profit I wonder what I can get it direct from the factory for since there local to me might give them a call next week
They will most likely say if you buy 2000 pellets you can have it at that price but I will give it a try
PostPosted: Mon Dec 28, 2015 2:43 pm
Just got back from Supercrap, no Gulf Western left, or Magnatec 15W/40 (for my Jeep) either!
They are a PITA for keeping stock, they didn't even have any 2 stroke lawnmower oil either. :evil:
PostPosted: Mon Dec 28, 2015 9:25 pm
So the diesel 15W40 oil that GR talks of is fine to run in the mini? I keep seeing it in the 20 litre drums for $70-odd bucks. If this is compatible, I will use it in both the mini and the pootrol. I have always shied away from the diesel oils as I thought they were only for diesel cars...now I might just buy it up in bulk and decant it away in the garage.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Dec 28, 2015 10:13 pm
Hooroo
Nothing wrong with using diesel oil in petrol engines, me and my friends used to use Shell Rotella in out Fiat 124 coupes back in the 70s.
PostPosted: Tue Dec 29, 2015 8:24 am
I remember the days when petrol stations had 2 stroke pumps
I brought a 5 litre bottle of 2 stroke oil off them last year I've only just started using it
I know about the crap stock I went to get Honda mower blades on there 20% off boxing day sale the other day only 2 packs there and I wanted 4 packs this was at mt druitt asked the bloke if they had more and was told only what's on the shelves gets sold today
PostPosted: Tue Dec 29, 2015 10:36 am
Hooroo
But switching to diesel oils in an older engine can be harmful.
The diesel oils have a higher detergent level to remove carbon, if you have an old engine the new oil might quickly remove the built up carbon and block the oil filter in a couple of days.
PostPosted: Tue Dec 29, 2015 3:34 pm
Thanks Doc and Morris. Might run a cheap diesel 15W40 through the patrol and dump it after a couple of hundred Kay's and change up again. I recently had the tappet cover off to do some planned maintenance on the patrol and was clean as a whistle in there was very little in the way of deposits on anything. Tappet adjusted up and riddled myself of the annoying tappety tap inherent in the GQ TB42E and I dump the oil religiously every 5000km with a change of oil filter. I have half a dozen of the filters so have plenty to back me up.
Rob Forsyth
Miniot!!
PostPosted: Tue Jan 05, 2016 11:17 pm
Well bought 20 litres of diesel oil for the patrol and drained and refilled the car. Went for a drive and pressures are up from 4kg/cm3(Nissan gauges!) to 5kg/cm3 at idle and 5kg/cm3 to 6kg/cm3. Tappet noise is nearly non-existent and car is smoother and less noisy all round. Did both diffs as well as the gearbox and really happy with the big car now. I only hope the results are the same for the mini when I finally get him back on the road.
Hooroo
Rob Forsyth
Miniot!!
