It is currently Sat Aug 02, 2025 6:03 pm
PostPosted: Wed Dec 16, 2015 4:58 pm
Just some info on what I found when rebuilding one of my front hubs
I decided to go everything new
CV's Timken Bearings, Ball Joints, Disc Rotors
Just be aware when fitting new bearings and or CV's
The ones I used the CV end Bearing didn't fit the Shaft properly
The bearing inner radius or the CV radius were too small and wouldn't allow the bearing to fit right up to the shoulder
It came about 1mm from the shoulder and locked onto the shaft
So basically fit that bearing to the shaft first and see that it slides up to the end shoulder and you cant see daylight
I had to machine the CV and the bearing radius to get a nice fit
Will try to get some photos to explain better
1970 MK2 Cooper S
PostPosted: Wed Dec 16, 2015 9:28 pm
Sounds like the new CV was faulty. Bearing usually slides right up.
PostPosted: Thu Dec 17, 2015 5:55 am
Yes it should
But what i am saying is that it is a trap for young players
Most people would just put things together without looking
1970 MK2 Cooper S
PostPosted: Thu Dec 17, 2015 10:10 pm
Last set of CVs I tried didn't have enough spline machined on them and when the drive flange was fitted it bottomed out on the spline run off before the bearing seat. Check that too!
Users browsing this forum: Steam and 87 guests
