It is currently Sat Aug 02, 2025 6:09 pm
PostPosted: Mon Dec 14, 2015 10:15 pm
Does anyone have a photo of the studs which the dry subframe uses to bolt to the engine bay cross member?
I seem to remember they are 9/16" one end and 1/2" the other with a taper on the shank.
I am more used to hydro frames and all my bolts are off being plated :)
PostPosted: Tue Dec 15, 2015 7:22 am
i think more like 3/8"x5/16"either end
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
PostPosted: Tue Dec 15, 2015 7:53 am
Yes, and with a reduced shank rather than a tapered one.
PostPosted: Tue Dec 15, 2015 10:48 am
Ah yes. sorry I stated AF instead of thread size...
Thanks very much. For the moment I will use a pair of gearbox studs to line it in place. They're 3/8 UNF to 3/8 UNC but will do to get the thing lined up until I get the bolts back.
PostPosted: Tue Dec 15, 2015 1:53 pm
I'm not all all sure how that will go for you. The holes in the bulkhead cross-member will be expecting a 5/16" stud, won't they?
PostPosted: Tue Dec 15, 2015 1:55 pm
They accept the 3/8 studs and I think they would accept more!
A lot of leeway for chassis alignment I suspect. They wouldn't be built this way these days...
PostPosted: Tue Dec 15, 2015 5:45 pm
Even with all that leeway, when I swapped to a GT subby in mine I had to chase one of the subby threads in situ. I have a 5/16 UNF tap with 200mm of square bar welded to it. :)
