It is currently Sun Aug 03, 2025 12:42 am
 Post subject: Is this +60 oversized?
PostPosted: Tue Dec 08, 2015 7:04 pm
I took the head off the engine today to have some work done on it and also to figure out if the block had been bored before so I cleaned the carbon off one of the pistons to unearth the below... is this 60 thou over?? if so what does that make the capacity... 1330?
Jenk.
PostPosted: Tue Dec 08, 2015 7:15 pm
yes
yes
PostPosted: Tue Dec 08, 2015 7:48 pm
The piston is a Hepolite Cooper S piston.
9.75:1 compression ratio on a standard bore.
2 compression rings and one oil ring.
A good quality UK made piston.
Hope this helps.
PostPosted: Tue Dec 08, 2015 7:52 pm
Hope this helps.
thanks but now I'm confused if its a standard bore why does it have +60 on it? so you're saying its 1275?
Jenk.
PostPosted: Tue Dec 08, 2015 8:27 pm
All compression ratios are worked out on a standard bore.
1275 bore is 2.780".
Standard size 21253 pistons = 9.75:1
+060" = 1327cc.
With no head work,etc comp ratio wld be about 11:1 .
You would need see see what head volume you have (std is 21.4cc) plus deck height and bowl size.
PostPosted: Tue Dec 08, 2015 8:31 pm
+060" = 1327cc.
Awesome thanks.
Jenk.
PostPosted: Tue Dec 08, 2015 8:35 pm
I have the same pistons in my car and I have just cleaned up the head and cc'd it.
My head has only had a mild skim and the chambers measured around 20cc.
A 40 thou head gasket gave me 11.5 to 1 CR and with a 60 thou head gasket I got 11 to 1 CR.
I use this calculator
http://www.gtsparkplugs.com/CompRatioCalc.html
PostPosted: Wed Dec 09, 2015 6:14 am
Thanks gtogreen.... that's a handy calculator.
Jenk.
