It is currently Sun Aug 03, 2025 1:06 am
 Post subject: Carb Spacer Required?
PostPosted: Tue Dec 01, 2015 10:49 am
Hey All,
Do you need to use a spacer between the manifold and the carby? (HS4)
What is the purpose of them anyway?
Thanks!
1975 Hairy Lime/White Clubby
PostPosted: Tue Dec 01, 2015 11:21 am
I think the throttle cable brackets are designed to use them and might be at slightly the wrong angle without them? I think I have a spare alloy one if you are interested?
PostPosted: Tue Dec 01, 2015 3:59 pm
Righto, I guess I just need to do a test fit and see what happens.
The only other issue I can see is the un-threaded section of the stud on the manifold might be too big without a spacer to take up some of the room.
Thanks for the offer timmy, i'll let you know if I need it.
