It is currently Sun Aug 03, 2025 12:15 pm
PostPosted: Wed Nov 25, 2015 6:58 am
Hey guys!
Purchased a 73 mini with a 1098 (I think, eng prefix 1001) and I've noticed theres an oil leak around the oil pressure switch. It seems to be coming out between the switch and the block.
Is there a gasket? Can I just put some sealant on the thread? Or should I replace the switch?
What size spanner/socket fits over it?
Thanks :) pics of car to come soon!
Adam
I have a problem.. apparently
PostPosted: Wed Nov 25, 2015 7:19 am
Clean around the area with a bit of degreaser to see exactly where the leak is coming from , more than
likely coming from the threaded section of the switch , albeit they can leak from the switch itself .
They don't have a gasket, you can use some liquid sealent around the thread .
PostPosted: Wed Nov 25, 2015 7:52 am
Thanks, mate. I can definitely see it weeping out from below the "head" where the spanner goes to tighten it. Will wack some goo on the thread :)
PostPosted: Wed Nov 25, 2015 8:19 am
Give Ash some flowers Nick .
I'm pretty sure the thread is 1/8" NPT - national pipe taper. It shouldn't nead a gasket as the thread is tapered. If anything, some medium loctite or similar should seal any gaps in the thread / try some plumbers teflon tape to seal it up.
PostPosted: Wed Nov 25, 2015 8:38 am
Looks like the switch is only $11. Might just be worth getti ng a new one
PostPosted: Wed Nov 25, 2015 8:49 am
Nope the thread in the block is definitely 1/8 BSP, parallel. A 1/8 NPT one (very common aftermarket switch) will screw in a bit, but is prone to leak. The NPT thread is bigger, and 1 tpi different.
I'd try some sealant (NOT teflon tape!) but if still leaking, buy the right one.
PostPosted: Wed Nov 25, 2015 9:06 am
I stand corrected then!
Looks like I've been using the wrong ones for ages!
PostPosted: Wed Nov 25, 2015 9:19 am
Is it a part I can get from repco, or am I better off heading out to mini king?
PostPosted: Wed Nov 25, 2015 10:00 am
The ones you get from Repco are the ones like I have that are 1/8 NPT not 1/8 BSP as that is where I got mine from to replace my old one that didn't earth out anymore.
PostPosted: Wed Nov 25, 2015 10:46 am
Ta. Mini king it is :)
PostPosted: Wed Nov 25, 2015 11:41 am
A 1/8 BSP dienut is a handy thing to have. :)
The British car industry never standardised properly on threads in the 60s, a Mini hydraulic stoplight switch is 1/8 BSP. A Hillman Imp one (looks almost same but NLA) is 3/8 UNF, go figure. (so my 3/8 UNF dienut was handy for my bro' too!)
PostPosted: Wed Nov 25, 2015 7:02 pm
probably just needs a new copper washer
PostPosted: Wed Nov 25, 2015 8:34 pm
How do I even get a bloody tool on it!
PostPosted: Wed Nov 25, 2015 8:45 pm
Smaller tool is needed, mine fits ok.
PostPosted: Wed Nov 25, 2015 9:14 pm
deep socket?
take the oil line off and use a spanner?
