It is currently Sun Aug 03, 2025 12:15 pm
PostPosted: Mon Nov 23, 2015 7:13 pm
Hi everyone
Quick question, I've noticed oil coming out from the dipstick, im wondering is this due to pressuring?
The motor is a 1330 (1275 out of a 1100s) the only breather on the motor is out of the rocker cover, im thinking maybe this is the problem, any help is appreciated
PostPosted: Mon Nov 23, 2015 7:19 pm
My car did this from excessive crankcase pressure at high rpms. I only have the rocker cover to breath from but the PO put a second outlet on it.
I tried to run a completely sealed system but the PCV valves would not flow enough over 6500rpm. I would end up with oil on my front valance, starter motor, horn etc.
Now I run into a vented catch can before my PCV valve so the extra pressure is vented off at high rpms.
PostPosted: Mon Nov 23, 2015 7:36 pm
Thanks, I thought it must be due to pressure build up, pics help too, might make something similar
PostPosted: Tue Nov 24, 2015 6:39 am
hey gtogreen1969, did you install the crane electronic ignition (noticed in your piccy fireball xr700), haven't seen one in a mini before, ?Darryl
PostPosted: Tue Nov 24, 2015 7:13 am
It was there when I bought my car but I am changing it out for a powerspark high energy dissy and high energy coil.
PostPosted: Wed Nov 25, 2015 10:37 am
What's the reason for the change? I'm using the fireball in my current build (I haven't set it up yet)
PostPosted: Wed Nov 25, 2015 12:00 pm
PM sent. Don't want to hijack this thread.
