It is currently Mon Aug 18, 2025 10:33 pm
 Post subject: Wheel stud length?
PostPosted: Sun Nov 15, 2015 7:57 pm
Evening all. How much stick out should I be running on the rear wheel studs? This seems inadequate, but I was given these studs when I asked for ones to suit the finned drums with built in 1" spacer.
compared to the front:
I know there are different length studs. Should I be sourcing a longer set?
 Post subject: Re: Wheel stud length?
PostPosted: Sun Nov 15, 2015 8:07 pm
If i recall correctly 13mm engagement of the nut was the engineering spec ( 1 -11/2 times width of stud) so 3/8 times 1.5 close enough to 13mm.. put your wheel on to be sure
PostPosted: Sun Nov 15, 2015 8:18 pm
Okay thanks FNQ, sounds like it's all good!
(btw I am exchanging the alloy wheels I have and I don't want to soil these new rims so I can return it in mint condition)
PostPosted: Sun Nov 15, 2015 9:36 pm
the required length of your studs also depends on the wheels and the nuts that you are using
in victoria, the roadworthy requirement for wheels/studs/nuts is...
Wheel nuts must engage the thread of the wheel stud for at least the same length as the original wheel nut and have the same taper as the mating wheel stud hole
1975 Hairy Lime/White Clubby
PostPosted: Mon Nov 16, 2015 6:53 am
Okay thanks Thorlek
PostPosted: Mon Nov 16, 2015 5:35 pm
Totally depends on the wheel/nut combination.
Wheels like contessas which use a nut that fits within the rim go close in to the drum. Some other rims like performance superlights, especially ones fitted with steel inserts the wheel nut seats a lot further away from the drum, often needing longer studs.
PostPosted: Mon Nov 16, 2015 8:49 pm
Thanks Matt. Just making sure it is around about the standard length as I know the rims will work with a standard length stud. I'll double check the specific size with the wheels when they arrive thanks :)
Users browsing this forum: No registered users and 317 guests
