It is currently Tue Aug 19, 2025 7:50 pm
PostPosted: Thu Nov 12, 2015 7:51 pm
I was thinkig about getting me an air flow meter so i can tune my Twin Su set up properly.
the LM2 has data logging.
Does any one have one of these and is it easy to use.
http://www.innovatemotorsports.com/xcar ... t=0&page=1
Thanks
Kiwiinwgtn
PostPosted: Thu Nov 12, 2015 11:26 pm
Give Ash some flowers Nick .
I don't have one of those but I do have an AEM wide band. I put the gauge in a jiffy box from Jaycar and made a tail pipe exhaust sniffer to weld the bung into. Well worth the money if you do get one. I think drmini has a Innovate wideband - I'm sure he will chime in.
PostPosted: Fri Nov 13, 2015 5:09 am
It's an air/fuel ratio gauge rather than an air flow meter.
Air flow meters measure the volume of air going into the intake system
Air/fuel gauges measure the mixture in the exhaust system
PostPosted: Fri Nov 13, 2015 5:12 am
I've got a basic unisync to balance my twin SU's.
PostPosted: Fri Nov 13, 2015 7:03 am
I have used the Innovate LM-1, I borrowed GR's. It works fine. LM-2 is much the same but with data logging.
I have since built two Innovate MTX-L ones, I made them portable in a Jaycar jiffy box.
The tailpipe bracket I copied from the LM-1.
Since the pic was taken I have added a 12V cable option with a cig lighter plug, so I can run it in modern cars.
[edit] The MTX-L also has outputs for data logging.
pics-
Last edited by drmini in aust on Fri Nov 13, 2015 7:07 am, edited 2 times in total.
PostPosted: Fri Nov 13, 2015 7:05 am
Balancing twins is one thing, getting the A/F right is another...
PostPosted: Fri Nov 13, 2015 8:12 am
I had an Innovate LC-1 and have now upgraded to a MTX-L. Both worked well, were easy to use, and can be used to help select a needle and dashpot oil that is correct for your setup.
For datalogging I used my phone to video the display mounted on the dash.
This came in handy when my exhaust clamp unscrewed itself whilst driving at 80kph. The exhaust clamp fell off and I was able to track where it fell off by looking at the video. Then it only took about half an hour to find it on the side of the road.
PostPosted: Fri Nov 13, 2015 9:19 pm
Thousands of people wouldn't believe that...but I think its neat :!: Well done.
PostPosted: Sat Nov 14, 2015 12:23 pm
MinisPlus
I have a LM2 and use it regularly for tuning bith my own and customers cars.
I find it really good and very reliable.
I bought the kit with the hard case and extras including the suction mount and tend to use most of them.
Probably have had it 4 years now. Had to replace the sensor once but that was my fault, it didn't like getting very very wet with cold water when it was hot....
How can it be rusty when it's covered in so much oil?
PostPosted: Sat Nov 14, 2015 5:16 pm
I am wanting to sort out the fuel mixture on my twin 1.5 su carbs.
Can you also log rpm with the data logger by just connecting to the coil.
Ta kiwiinwgtn
PostPosted: Sat Nov 14, 2015 5:31 pm
MinisPlus
There is an inductive clamp that came with mine that clips onto a plug lead, much the same as a timing light. This plugs into the unit and you can then log rpm and fuel mixture.
On mine the info is stored on an sd card which you then plug into the laptop.
Most of the time I just use it with the o2 sensor only and take it for a drive, figure out what's going on and change needle, spring and oil to get it spot on.
PostPosted: Sat Nov 14, 2015 6:37 pm
Thanks. You comments have been very useful. I think I will just buy the lm2 basic kit and the inductive pick up.
PostPosted: Sat Nov 14, 2015 7:20 pm
http://www.trademe.co.nz/Browse/Listing ... =979603553
Found this. Could be the way to go.
Users browsing this forum: No registered users and 117 guests
