It is currently Tue Jun 24, 2025 5:24 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 15  Next
PostPosted: Tue Nov 10, 2015 10:35 pm
simon k wrote:
MiniMan_Alis wrote:
it also looks like there is a bit or positive camber on the front.
he's got plenty of adjustment there... ;)
Correct. When sitting on the ground it actually has negative camber. The photos don't show it correctly.
The rear engine mount bolt to the same spot as the original one did. The rear trans.
50mm poly bush. The engine barely moves which is great.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Tue Nov 10, 2015 10:37 pm
Harley wrote:
Your rate of progress is incredible - and unfair!
It'll be running by christmas! Great work!
So far so good but time is limited before xmas and there is some outsourced work required so not likely. I was aiming mid next year but being impatient it will be sooner.
1961 Morris mini
PostPosted: Wed Nov 11, 2015 7:01 am
You see that nub on the gearbox with the bolt in it? that's for the gear shifter stabilizer, you will probably be needing that. is the mount in the way of that now?
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Wed Nov 11, 2015 7:12 am
All good. That is why the mount has a bend in it. The stabiliser fits between the shifter and mount.
1961 Morris mini
PostPosted: Wed Nov 11, 2015 11:05 am
Goodo, just making sure.
loving the awesome work man.
can you legally put a b18 into a mini?
PostPosted: Wed Nov 11, 2015 3:37 pm
It's been done before...... :D
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Wed Nov 11, 2015 9:06 pm
Sure can. Based on the below table in the VSB14 you can depending on the weight of your car
My mini weighs about 700kgs so I could go up to a 2.1L N/A or 1.7L forced. If I could make it fit I could add a turbo to my B16A.
1961 Morris mini
PostPosted: Wed Nov 11, 2015 9:11 pm
I like your progress but if your engineer doesn't make you redo that mount I'll be amazed. I'd give it no time at all before it cracks just below the bottom bolt. I'd be be welding a plate to each side so it becomes 'C' or 'I' section.
M
PostPosted: Wed Nov 11, 2015 10:29 pm
Mmmmm B21vtec 13-14:1 compression easy 250whp with 4.7 final drive type R gearbox, In a 700kg Mini, that would be sick.
sorry I like hondas... a lot.. haha
PostPosted: Thu Nov 12, 2015 8:08 am
Better with a 3.7 final drive from Watsons Rally so you can use first gear, & not have to be in 5th gear at 60km/hr.
Yes, they are a lot of fun. :)
PostPosted: Sat Nov 28, 2015 8:27 am
Inlet manifold modified now.
It fits really well with good clearances. The welder did a great job with the die grinder too.
1961 Morris mini
PostPosted: Sat Nov 28, 2015 8:49 am
Thats fantastic! Looks like even the IAC valve on the back has plenty of clearance too. That'll save a lot of work in itself.
So whats next? Radiator or alternator?
PostPosted: Sat Nov 28, 2015 10:27 am
Yeh came up a treat. I am in the middle of doing the gear lever linkages which is also looking quite easy to do. Radiator will follow that.
1961 Morris mini
PostPosted: Sun Nov 29, 2015 8:06 am
Die Die Die!!
will you be fitting an airconditioner also ?
PostPosted: Sun Nov 29, 2015 9:21 pm
No A/C. I removed it when I supercharged the SPI as I never used it. I prefer the windows down although I rarely drive the mini when it is above 30 degrees.
1961 Morris mini
