It is currently Thu Aug 07, 2025 12:38 am
PostPosted: Tue Nov 10, 2015 4:44 pm
Hi there,
Newbie here with a Mini '73 MK3 Round Nose - South African body Mini (That's what I can gather from the history of the vehicle) Correct me if I'm wrong ;)
I bought is as is, and previous owner has done most of the job on this.
1275 Donk - twin 1.25" SU
Front brakes just clears 10" mini lites
Previously I owned a 1962 MK1 Mini 850 which was half way build with 1275 etc, but I sold it because changed in situations back then. Pretty disappointed that I sold it but oh well, Time to move on..
I now own the '73 for almost a year now, and its has been sitting duck in the garage due to a few issues. Which I have not actually solve, hence I joined the forum for a few tech Questions.
I have this Cut out issues while driving, Engine just died when driving.
I even put it on gears and it still doesn't fire up.
Once i pull over, and waited for at least 10-15 minutes, it then fired up again but may be another 20-50 ks down the road and it would cut off again, i would then repeat it again.
I have jumped the Immobilizers which I taught was the caused, and it wasn't
Checked fuses and replaced them.
I'm suspecting a faulty Distributor pick up, as i'm running mechanical fuel pump
or something to do with temperature - something gets hot and decided to die.
Since i wasn't the one who built up the car as current state, for my own piece of mind my current solution is to order up:
A new fuel pump
Re-do fuel hose lines (as its getting old and i've seen cracks on the soft hoses)
A new distributor
Interm of electrics, The car have Ground to body
and a new wiring kits layed out through out.
Could anyone suggested any directions for me to get the car up and running with out cutting out?
That would be great.
Thanks!
PostPosted: Tue Nov 10, 2015 4:59 pm
Next time it cuts out you need to run a few diagnostics (while its dead). Is there fuel in the carb bowls? Does the fuel pump pump? Is there 12v to the coil? Are the points opening (and closing:)? Is there a spark at the plugs?
If you have fuel and spark, air is unlikely to be a problem....
Cheers, Ian
PostPosted: Tue Nov 10, 2015 5:23 pm
looks to me it could be a rover. internal door hinges no quarter vent windows rover front grill ?
what does the interior look like ?
looks good though :) :)
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Nov 10, 2015 7:37 pm
Is that Inca Yellow?
It's nice to be important, but it's more important to be nice.
1979 998cc Leyland Roundnose Irish Mini
PostPosted: Wed Nov 11, 2015 5:12 am
could be the coil playing up. I had the same symptoms and it was a dodgy coil...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Nov 11, 2015 7:17 am
C.RUSLI wrote:
Hi there,
Thanks!
Interesting...I know that the Seth Afrikaans were/are well and truly capable of building or assembling just about any vehicle...but, for example, were MK3s ever CKD'd :?: :D
PostPosted: Wed Nov 11, 2015 2:16 pm
I don't think it's a rover, with non booster brake on the firewall?
Lots of yellow on the inside...
custom mid centre dash
Headunit located at the standard switch panel
I hate the yellow inside but, the wife seems loving it.. so I can live with that..
I got that on the order as well..
just pushed the order button on MiniSport.
I cant wait to play puzzle!
Would not have a clue... :roll:
PostPosted: Wed Nov 11, 2015 7:04 pm
twin 1.5" SU
as 1071 S said, next time it cuts out take the carb float bowls off and see if there's fuel in there.
It may be as simple as the wrong fuel filler cap or the tank breather blocked up
PostPosted: Thu Nov 12, 2015 2:22 pm
simon k wrote:
twin 1.5" SU
take (two!) the carb float bowl covers/tops off and see if there's clean fuel in there :D
Image[/quote]
PostPosted: Thu Nov 19, 2015 1:16 am
Humm... I just puzzle the car back together
And took it for a another spin at night.
When driving, again 10 minutes
Car died
Conditions before car died:
Key still on ignition
Headlight on
Dash light on
Drive normal
And then Car suddenly cut off when driving.
It Seems to be electrical problem
Car rolling still rolling with gear on but no power at all.
Ignition off ( no ignition light on dash either)
All lights off ( Dash light, headlight)
Rolling like a dead car.
Again waited for 10 min
Car starts and drive for the next 2 - 5 min and it will die again.
When the car is on idle
Check voltage on coil 5-6
volts
Battrey voltage at 14v (so generator is running)
I'm running out of option at the moment =/
Seems like the gremlins won again.
So far what I have done is
Change fuel pump
Replace vacuum hose
Replace fuel hose
replace coil
I tried fitted aldon red - electronic distributor with no starting luck ( cranks, spark, have fuel until flooded)
I'll try again later and will check the ignition lead order. I assumed it was the same as the Stock ones, may be not?
1 - 3 - 4 - 2
So I revert back to standard contacts vacuum dizzy and it starts straight away.
PostPosted: Thu Nov 19, 2015 1:23 am
Oh yes, I checked the car floats when it died.
There is fuel in there and it's clear
No dirt in it.
I also installed clear in line filter after the pump, and there is fuel. And no dirt.
PostPosted: Thu Nov 19, 2015 8:16 pm
Have you got a dodgy fuse. Carries current till it warms up and then breaks. Closes up when it cools.
