It is currently Wed Jun 25, 2025 3:54 am
 Post subject: Is this carb salvageable
PostPosted: Fri Oct 30, 2015 9:33 pm
I have two hs2 carbs, I want to change my single hs2 carb setup into a twin setup, is the carb on the right salvageable and can I use these two carbs in a twin setup, sorry if this is a stupid question, this is my first car and still learning all I can, This is to go on my 1098cc A series engine
PostPosted: Fri Oct 30, 2015 9:41 pm
it'll be fine...
PostPosted: Fri Oct 30, 2015 9:53 pm
And also Is it possible to use these as a twin setup instead of single, what would I need to do/ buy to them a left & right carb and linkage kits ect?
PostPosted: Sat Oct 31, 2015 6:08 am
You can't convert them to a true left and right set. But you can use two of the same side with a special linkage and a single choke. That's what the early tuning kits did. Have you got a manifold? I have a couple spare and some less crusty carbs too if you are interested
Here is the original tuning kit:
viewtopic.php?f=32&t=73875l
So you'll have the carbs and manifold like this
With the linkage setup similar to this
When you get the rebuild kit for the carbs, the new throttle spindles are normally a bit longer than standard, which is what you need. You can then join the throttle spindles similar to above.
PostPosted: Sat Oct 31, 2015 8:55 am
Thanks for the help that's exactly what I was wanting to know and I don't have a manifold and I would be interested thanks
PostPosted: Sat Oct 31, 2015 11:34 am
Kits were sold by BMC back in the day for Minis and Morris 1100 using 2 carbs like that.
My 850 had a set when bought.
They worked OK, however the choke is only connected on one carb.
Only problem I found is the W clips on the throttle joining shaft tend to bite into it, making throttle synchronization a hit and miss affair.
PostPosted: Tue Nov 03, 2015 12:08 pm
I've sent you a PM
Users browsing this forum: No registered users and 27 guests
