It is currently Sun Aug 03, 2025 1:16 am
PostPosted: Sat Oct 03, 2015 8:37 pm
Hi all
Just a couple of questions re heater:
What material do I use on the metal flap and how is it positioned?
How do I remove the fan from the spindle?
Thanks for any info.
Eiles
PostPosted: Sat Oct 03, 2015 9:21 pm
Just slide the fan off the spindle, it just presses on.
PostPosted: Sat Oct 03, 2015 10:57 pm
Thanks Morris
I'll give it a good go. I was a bit hesitant using too much force in case there was something holding it in.
PostPosted: Sun Oct 04, 2015 8:53 am
I'd just watch the plastic fan after 40+ years the plastic could be brittle and break
PostPosted: Sun Oct 04, 2015 9:18 am
re your question about flap seal material, when I did up my `matic heater I used closed cell foam on it. it's about 6mm thick.
PostPosted: Sun Oct 04, 2015 11:04 am
Thanks guys.
Will take care with the fan (gently, gently).
Cell foam sounds the go.
PostPosted: Sun Oct 04, 2015 5:38 pm
I used circlip pliers to remove the metal clip from the fan first as this is the thing holding it tight. it is a tedious job to remove it but patience is your friend. clean the shaft with some emery paper and spray with some wd40 or similar before removing the fan.
PostPosted: Sun Oct 04, 2015 8:12 pm
Thanks Brian
PostPosted: Sat Nov 21, 2015 8:48 am
More questions :)
The heater core seems to have foam (?) wrapped around its body. What is its purpose and is it a special material (heat resistant etc)?
Eiles
PostPosted: Sat Nov 21, 2015 11:01 am
The heater core foam is to minimize the potential of the air to flow around the core instead of through it, but also to help locate the core in the heater box. There is probably more benefits that I've forgotten too.
Cheers Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Sat Nov 21, 2015 12:19 pm
Thanks Brad!
I've been holding back the refurb till I was a bit more informed.
PostPosted: Tue Nov 24, 2015 8:47 am
Grommets for heater core inlet/outlet pipes.
Having probs getting replacements for these grommets:
Any help muchly appreciated.
PostPosted: Thu Dec 03, 2015 9:08 pm
hello, i like your topic.
i will remake one, if you have another pics.
thanks
Arnaud
http://clubmangt.skyrock.com/
http://arnaud-offroy.skyrock.com/
Long live to carburetors and 10 inch
