It is currently Mon Jul 14, 2025 5:38 pm
 Post subject: Starting problems
PostPosted: Sun Sep 13, 2015 3:02 pm
Hi,
I am a newbie,and need some advice on starting problem. I have just hadfitted new coil,leads,dissy cap and rotor button as well as new plugs, I run electronic ignition,but since all these replaced it is very hard to start, 15 minutes this morning. When it's going it runs beautifully. That said it just keeps cranking over and over for a long time before it fires,any help welcomed,
Cheers Mal
 Post subject: Re: Starting problems
PostPosted: Sun Sep 13, 2015 3:03 pm
What plugs did you fit? Are they getting wet when cranking?
Is the timing the same as before as well? What timing setting did you put it to?
PostPosted: Sun Sep 13, 2015 5:01 pm
Thanks for the reply Mick,it was all done by a mini specialist in Melbourne,so I imagine every thing should be right,they thought it may be old fuel,but refilled it ,same problem still.
PostPosted: Sun Sep 13, 2015 7:43 pm
I'd be taking it back to them to have a look at. My machine gives me the irrits like this when it hasn't run for a little while, but it fixes itself. But if you went from an engine which started smartly then something has changed.
All of the above will do it, but if mixtures have been changed or some other wild card, then it will be easier to have the tuners chase the problem out in my opinion.
PostPosted: Sun Sep 13, 2015 7:50 pm
Thanks Mick, I will ring him again tomorrow,certainly annoying took 15 minutes to start this morning.
PostPosted: Mon Sep 14, 2015 7:20 am
Online
What carby is it running ,and is the choke connected and working ?
PostPosted: Mon Sep 14, 2015 8:21 am
running inch and three quarter su,seems to be working ok.
PostPosted: Mon Sep 14, 2015 9:55 am
Get someone to pull the choke out fully while you watch the Carbie. You should see the jet drop down. If this doesn't happen then it's not getting the extra fuel needed for cold start.
PostPosted: Mon Sep 14, 2015 11:14 am
Thank you, will check it out.
PostPosted: Tue Sep 15, 2015 6:12 am
Winding the engine for 15 minutes to start? Not exactly what a starter motor is designed to do.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Wed Sep 16, 2015 5:54 am, edited 3 times in total.
PostPosted: Tue Sep 15, 2015 7:26 am
Convertible Mini wrote:
Winding the engine for 15 minutes to start? I can see you looking for another starter motor soon if you don't get it fixed.
Is that a sales pitch? :-) :-)
Could be one of many things, but I too think you should take it back to your repairer. Maybe something they fitted is faulty or on wrong but if you start fiddling with it then they could wipe their hands of it. You might need to leave it a few days for them to test it each morning cold.
PostPosted: Tue Sep 15, 2015 7:54 am
Online
Could possibly have a crook ignition switch , try winding it over for a short time , and see if it fires when you release the key , i have seen this several times before .
once you have had it running , try just a quick flick of the key to see if it fires up .
PostPosted: Tue Sep 15, 2015 8:03 am
Thanks Goodie, I think your on the right track,once it has been warmed up it only needs a quick turn of key and it fires up.
PostPosted: Fri Jun 08, 2018 2:04 pm
HI sorry for the old thread. just wondering how do you see it when its all sealed? or do you have to pull AirFilter off?
Thanks Brett
PostPosted: Fri Jun 08, 2018 2:15 pm
You can see the jet underneath the carb. When the choke is pulled the lever lowers the jet (black plastic on the left carb)
Users browsing this forum: goodie and 93 guests
