It is currently Sun Jun 22, 2025 8:43 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 15  Next
PostPosted: Thu Sep 03, 2015 8:11 am
I have a 1989 rover body you could have used instead of pulling your late model car apart.
Its on Ebay until the weekend.
Alpine moke
PostPosted: Thu Sep 03, 2015 12:17 pm
please get some proper axle stands... bricks shatter
PostPosted: Thu Sep 03, 2015 12:27 pm
Still planning to build your own frame or jump the shark and just buy one?
PostPosted: Thu Sep 03, 2015 1:59 pm
Still going to build it at this stage
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Sat Sep 05, 2015 3:05 pm
Another couple of hours has seen the inner guards removed, the front panel opened up, the dash pulled out & the pedal box removed. No turning back now.
1961 Morris mini
PostPosted: Sat Sep 05, 2015 3:35 pm
Things will start looking scary soon when the engine goes in - even without the frame!
PostPosted: Sun Sep 06, 2015 11:20 pm
So exciting!
I love the reasons for doing this swap you gave on the last page. If there was a thumbs up smilie i would use it here
1963 850 - laid up
PostPosted: Thu Sep 17, 2015 7:21 pm
I started draft 1 of my subframe on the weekend and dropped the engine in. As expected the steering rack is going to cause problems. I replaced the bolt with a counter sunk screw and ground the rack back but still no good. I can't afford to move the engine forward or else I will not get the radiator in and the drive shafts will be on too much of an angle.
I have read other posts about the steering rack but I think I am going to have to work on another solution. I also don't want to cut the floor to push it back either.. Fun and games.
I Used 50x25 RHS but thinking it might need to be 40x25
If you have any other ideas on a rack solution then let me know.
Birds eye view of the steering rack
1961 Morris mini
PostPosted: Fri Sep 18, 2015 10:31 am
40 x 25 isnt a standard size (unless you can find some 1.5 x 1").
I would've preferred that size but got stuck with the 50x25.
If i started again I'd probably look at 30x30.
PostPosted: Fri Sep 18, 2015 1:02 pm
Just as a general overview this is usually helpfull for size availability
http://www.onesteel.com/images/db_images/productspecs/DCT_CF.pdf
Nick
PostPosted: Fri Sep 18, 2015 11:00 pm
40x 25 would be ideal but not available as you both mention. The closest I can get is 38x25x2mm Galvanised RHS (rather than painted) so I am off to the steel supplier next Monday to purchase some for Draft 2 next weekend.
The Engineer has approved it too which is a bonus.
The extra 10mm space will make a big difference I reckon.
1961 Morris mini
PostPosted: Sat Sep 19, 2015 11:31 am
If your engineer has approved it thats good, but when you go to the steel supplier make sure you check if that imperial steel size has an AS/NZS 1163 standard and an absolute minimum 250 mpa tensile strength. Anything less and you'll get problems with the frame cracking.
PostPosted: Mon Sep 21, 2015 10:58 pm
Yep, all approved. 38x25x1.6 RHS All Gal tubing. I have just ordered it and pick it up Thursday. Ready for the weekend.
On another note, I have cut away another 5-7mm from the rack and sealed it back up. Every mm helps
1961 Morris mini
PostPosted: Wed Sep 23, 2015 9:49 am
Engineer didnt mention any concerns over the thin wall of that tubing?
PostPosted: Wed Sep 23, 2015 9:57 am
Nope. Criteria is:
RHS and not ERW tubing. ERW is the common type and pretty must in stock at most places. The RHS is not common and so I had to order it in. The steel place didn't even know it existed. Ha
it is also 350 grade so should be ok.
Also, The frame must have supporting lower legs from front to back and gussets where the new frame meets the original frame.
1961 Morris mini
