Goldbrocade_62 wrote:
When did they break during assembly or driving
I believe this ring breakage to be an isolated case, first time I've seen Hastings rings give a problem on a road motor.
This motor (+.060" bore stroker) was built, then run in on GR's dyno a few years ago. Then it had power runs. It made 103HP @ the crank which was good for its spec.
[edit] It then sat unused (with oil in the bores) for ~2 years whilst the owner worked on the car.
Back on the road January this year.
2650km later, it was huffing and puffing out the breathers.
Pulled down, it revealed the top ring on #1 piston had broken 1" from the end some time ago, it wrecked the ring lands and wore the bore at the top.
#2 piston's top ring had a fresh recent break, 3mm from the end. It had not done any damage.
We tried a spare Hastings ring in the #3 bore and it had approx a .013" gap.
So, it would appear that these 2 rings broke many miles apart.
The motor is now running again with a fresh rebore, GR's 72.5mm pistons and a Nippon ring set.
The PCV valve is pulling good vacuum today, so no blowby.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
