It is currently Mon Jun 30, 2025 9:07 pm
 Post subject: Alloy rocker cover
PostPosted: Sun Jul 19, 2015 3:43 pm
Does anyone have any information on this rocker cover, is it rare or anything? Cheers. Richard. Image
 Post subject: Re: Alloy rocker cover
PostPosted: Sun Jul 19, 2015 4:45 pm
nope not rare.
PostPosted: Sun Jul 19, 2015 5:24 pm
TK wrote:
nope not rare.
Thanks bud.
PostPosted: Sun Jul 19, 2015 8:33 pm
They were sand cast, Australian made, most have no maker's name, but the one on Laingy's 1387 Mini van does .
I had one on my 1412 stroker.
They are quite a solid casting, unlike the flimsy diecast Chinese ones being sold now.
PostPosted: Tue Jul 21, 2015 12:00 pm
Thanks doc, no makers name on mine. My 1.5 roller tip rockers fit under so I'll be sporting a new cover.
PostPosted: Tue Jul 21, 2015 7:11 pm
I've gone back to an original tin one as the alloy one I had on was fouling on the rockers. I think it was because the grommets were a bit flogged though. I might pull it out and grab a new set.
PostPosted: Tue Jul 21, 2015 7:35 pm
Evan,
Sometimes you need to move rocker covers back a bit to clear hi-lift rockers. Particularly if you are running my Corolla ones still.
I don't use the rubber grommets now, the crap rubber they are made from is allergic to oil. I cut polyurethane washers and fitted them instead.
PostPosted: Thu Jul 23, 2015 7:49 pm
Good idea Doc. I did note that they would clear by moving the cover back slightly but my grommets were already prerty shat. Time to revisit.
PostPosted: Fri Jul 24, 2015 6:52 pm
With that alloy cover you don't need a grommet through the hole.
I can make you a couple of 5mm thick poly washers, but not until after 1st August. My mate has my bit of poly sheet, and he's on hols.
PostPosted: Fri Jul 24, 2015 7:59 pm
Just get some new grommets from Lincoln and slice off the bit that goes through the hole. Tighten down the cover a little and push it back. Finally tightly finish it off white holding it back.
This should then give an extra 3 or so millimetres clearance. Done. xxx
PostPosted: Tue Sep 06, 2016 9:03 pm
Bit of a thread dig... any idea on the maker?
PostPosted: Tue Sep 06, 2016 10:51 pm
Nope. I have an unmarked one too, although I could get my 1,5 roller rockers to fit if I positioned it just right.
PostPosted: Wed Sep 07, 2016 6:32 am
Laingy's one has the name 'T J Dunn and Co, Sydney' cast on top.
PostPosted: Wed Sep 07, 2016 12:39 pm
Lynx was who I thought might have had something to do with making the finned A-series and B-series ally covers here.
Castalloy in Adelaide and Monaro Motors in Melbourne were other makers but in the 1950s.
....you just lost him his insurance bonus!
997
PostPosted: Wed Sep 07, 2016 4:11 pm
I have the same alloy rocker cover (albeit somewhat modified) on my Bugeye Sprite motor. I always thought it to be a Lynx product, but there's no manufacturer's markings on it as far as I know.
Curly
