It is currently Sat Jul 19, 2025 2:43 am
PostPosted: Mon Jul 13, 2015 11:53 am
Hi guys,
I've got a 1970 Leyland Mini Clubman and I need to find an exterior door handle as mine somehow fell off, but I have looked at heaps of English and some Aus sites and can't find one. I saw one on eBay but it was rusted and in poor condition. Is this part normally so hard to find? I will go with the eBay one if nothing else is available. Do you have any info that could help?
Thanks!
Stefano
PostPosted: Mon Jul 13, 2015 12:09 pm
They were only fitted to late Australian cars, so you won't find any in the UK
PostPosted: Mon Jul 13, 2015 12:15 pm
http://minisport.com.au/secondhand-parts
They are a bit expensive, but they do have them :)
PostPosted: Mon Jul 13, 2015 12:23 pm
Try mini kingdom online john should have some
That mini sport place must be the only parts place in south aus so the can charge what they want
PostPosted: Mon Jul 13, 2015 2:29 pm
Stefano132 wrote:
Hi guys,
Thanks!
Stefano
I have a spare one, pm if want.
PostPosted: Tue Jul 14, 2015 11:06 am
There is a pair on ebay now
http://www.ebay.com.au/itm/1973-Leyland ... 419981a364
PostPosted: Tue Jul 14, 2015 4:13 pm
I also have them in stock
Matt
Bne
PostPosted: Thu Jul 16, 2015 1:38 pm
Thanks so much for the help guys! I have a friend who is saying he can find it for me so I'll try my luck with him. If not, I'll be are to hit you up!
Stefano
PostPosted: Thu Jul 16, 2015 1:53 pm
Remember that they are handed (left & right) and it's always the driver's side that wears out where the pull rod goes into the hole in the tab under the handle.
Then people just try pulling up harder and snap them off.
PostPosted: Wed Sep 20, 2017 11:52 pm
Hi, hope you don't mind me digging up an old post. I'm looking at purchasing a 1978 leyland mini and the driver's side door handle is "floppy". The owner said something about a pin snapping inside so I wanted to find out whether I can realistically fix the issue without spending more than a couple of hundred dollars. I'm wondering if it is the pull rod as you've described and if so whether that's a part I can easily find?
Appreciate any suggested contacts or links. Great forum by the way!
Bas
PostPosted: Thu Sep 21, 2017 9:43 am
If the handle has gone floppy, then I'm afraid it's at the stage where one of the hinge pins has been snapped off and it's time to fit a new handle. One of the suppliers mentioned above should be able to help.
PostPosted: Thu Sep 21, 2017 3:24 pm
Sometimes you can replace the pins that the flap hinges on. I've had the pins slide out but stay trapped in there. I've also seen them with the socket that the pins press into all broken, in which case there's not much you can do. Its one of those horrible soft diecast alloys that are very hard to repair.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Sep 22, 2017 8:14 am
Thanks for the responses. That's helped.
Sent from my SM-T810 using Tapatalk
PostPosted: Fri Sep 22, 2017 12:59 pm
Are .orris 1500 ones the sMe?
PostPosted: Fri Sep 22, 2017 3:22 pm
According to the parts book - YES, same part number.
