It is currently Sat Jun 21, 2025 2:39 am
Post new topic Reply to topic  [ 221 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
PostPosted: Fri Jun 05, 2015 10:54 pm
Hi All,
For years I have wanted to Vtec my mini but instead have converted my 1L auto to an 1.3L SPI Manual then decided to supercharge it. I should have followed my gut and put a Vtec in it.
Well now it is time.
My current mini engine details are below and can be found on http://www.dutchysmini.com/supercharging.html :
88 Rover mini
1275 Manual - Standard bottom end
Ported head, 35mm inlet valves
Ceramic coated Exhaust manifold
Eaton M45 Supercharger
Custom made inlet manifold
3 x 646cc Siemens injectors
2 core radiator
new clutch & seal
Autronic SM3 ECU (SM4 firmware)
The Honda:
I purchased a JDM B16A complete with manifolds, 5spd transmission, ECU, engine wiring, gear linkages, driveshafts & dash cluster.
I am aiming to build my own frame to fit the B16A into my round nose without extending or modifying the front.
Tough ask from what I can see and from what most people on here are saying.
I have discussed with my engineer who has given me all the relevant info to get it passed and registered.
IN the mean time, a few goodies have been purchased.
- Wilwood Pedal kit from Minitec
- Minisport 4 piston calipers & 8.4" vented and slotted front discs
- Stainless exhaust manifold
- New Radiator & hoses
- Second hand rocker cover - cleaned and blasted ready for red wrinkle paint
I was considering buying a half cut and working with that for the subframe build but after much thought i think it will be better to use my body and strip my engine out.
Before I do I was was thinking of seeing what interest is out there for my complete engine with supercharger and ECU. You could pretty much drop it in, wired it in and away you go.
Any ideas on what it would be worth? if anyone is interested then PM me to discuss. l want to leave it in the vehicle for serious buyers to test drive before pulling it out. Based in Melbourne VIC.
Dutchy
It will be a slow project but i will keep you all updated.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Sat Jun 06, 2015 9:53 am
Do you not like the supercharger set up? Just wondering why you want to rip it out after so much work.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Jun 06, 2015 10:20 am
Good luck with the build Dutchy!!
I'm from Melbourne as well and currently getting things organised to do a engine transplant just like you ;)
PostPosted: Sat Jun 06, 2015 12:32 pm
Keep us updated! This sounds like a great project, very keen to see how you tackle it
1963 850 - laid up
PostPosted: Sat Jun 06, 2015 4:04 pm
Love it especally like some of the parts, I had a look at your website and build log, should be great build to follow with Honda power.
Hoping to do much the same with mine, similar colour, but not same and no stripes, and same wheels 13 by 7 and same brakes but with Suzuki GTi power
PostPosted: Sat Jun 06, 2015 10:32 pm
Thanks all for your support.
@ Babes, it is well noted that minis like to breathe an when they say breathe they mean negative crank case pressure. Any forced induction is positive pressure and as well as the car goes it is almost like you are making someone do something they don't want to do. In the end I decided to do this project for several reasons.
- Reliability
- The 5spd manual
- Better fuel economy
- and something that isn't common in Australia. The challenge.
1961 Morris mini
PostPosted: Sun Jun 07, 2015 12:17 am
Sounds fair enough mate, look forward to the new build.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Jun 07, 2015 1:30 am
Dutchy want to group buy the subframes ;)
PostPosted: Wed Jun 10, 2015 8:31 am
Do you no they will offer a discount for two frames? A cant imagine the freight being any cheaper as it is usually cubed.
What do you think? Have you seen it done before?
1961 Morris mini
PostPosted: Wed Jun 10, 2015 10:04 am
From what ive seen on 16v forum discounts can be had from multiple purchases, but normally multiple is more than 2 (more like 5).
You may be able to save on shipping and import tax by getting them together though.
PostPosted: Sat Jun 13, 2015 12:28 am
If I won the lottery tomorrow I would buy an Allspeed frame but it would have to be a division 1 win and not the $14.60 I got last time.
Dutchy1978 wrote:
Tough ask from what I can see.
Can be done and plenty have. I'm currently doing my own as I haven't won lotto for a long while.
The engineer I talked to wanted FEA reports for the Allspeed frame. I'll give him FEA reports!!!
PostPosted: Sun Jun 14, 2015 8:59 pm
I hope you dont plan on using inventor for doing your FEA.......would be like trying to enter a tractor into a v8 supercar race! :P
PostPosted: Thu Jun 18, 2015 12:08 pm
I can only use the tools I have access to.
For me it's about, eventually, getting to the finish, not finishing first. Besides, didn't Lamborghini start out building tractors? :o
PostPosted: Sun Jun 28, 2015 10:10 pm
Keep us all posted !
If I hadn't gone down the WRX path I'd have fitted a B18 and the Allspeed frame. It keeps the track original and "just" fits in a roundy.
PostPosted: Wed Sep 02, 2015 10:27 pm
Finally got a start on the project last Sunday. Engine & subframe out. This weekend I will clean out the rest of the parts and if time permits start cutting out the inner wheel arches.
1961 Morris mini
