cooper66 wrote:
shnitzee wrote:
Thanks doc.
In your opinion, would it be worthwhile putting the 202 head on my 998 block?
Hi, in fact the 202 and 295 are the best for small bore motors, unfortunately in Europe we are not as experienced as you in Australia for small bore motors ... but we have beautiful engine tuning based on these cylinder heads. the chamber and valve size are good for this type of motor
The 12g240 (1275 head) is too much big for 998 and 1098, as the doc explained
to fit 1275 head on 998 is common in france and UK but it's not efficient for road motor
I would have to politely disagree with you.
I think it has been proven time and time again that the common A series engines (998, 1098, and 1275) are all capable of producing around 100 bhp per litre (at the crank) and the way to unlock most of this potential is in the cylinder head and the camshaft.
A Stock (cleaned up) 12G940 head on a 998/1098 when coupled with an appropriate cam will give a very drivable and enjoyable motor (once tuned) for much less than what it would cost the average enthusiast to get a professional to work their 202 head to the same spec. Now, if you're handy with a die grinder and have all of the burrs, stones, and pads that you need and can follow something like David Vizard's book and/or you have access to a flow bench that you know how to use then go and have a crack at it - there is a lot to be gained for a little more than your time.
