It is currently Tue Jul 01, 2025 7:44 am
 Post subject: BMW head and Moke update
PostPosted: Sat May 21, 2005 8:27 pm
Hi All,
I have just put a few updates up on Mark's BMW head conversion and my moke progress.
The head is comming along well with tha cam belt set up and the end plate in. Sorry the photos aren't great. It was dark when I took them so had to use the flash. There are larger pictures in the photos section of the web page.
I have got the new floor pans into the Moke with out too much trouble... besides my trip to hospital with Zinc Oxide poisoning. No body told me to grind the gal of first :-) well you live and learn. Don't look to close at my brazing work....
www.minimod.info
Jim
PostPosted: Sun May 22, 2005 4:23 am
moke007 wrote:
Hi All,
Thanks for the update, looks like you guys are making some progress 8)
What pulleys are you guys using to drive the cams? What pulley are you using for the crank? Also, can you set me straight on something. My thinking leads me to believe that the cam pulleys and crank pulley need to be matched in the correct ratio to keep the cams and crank synchronised in the same positions relative to each other. If that ratio is incorrect it's just not gonna work. So if you use the cam pulleys and crank pulley from the same vehicle it should work. Yeah?
Metal fume fever! Poor bugger, have a lie down and a drink of milk :oops:
If you'd taken some close ups we would have :wink: Did you get much warping with the oxy? Do the floor pans "pop" in & out when you put weight on them? I did a repair to the floor of my Suzuki and the floor pops a bit, because the panel is flat, no rigidity in it.
Anyway, thumbs up guys & keep the updates coming 8)
PostPosted: Sun May 22, 2005 7:14 am
That look Mean....and love the Idea...are you doing that to a Mk2 Cooper S Motor
Keep us updated :wink:
PostPosted: Sun May 22, 2005 8:15 am
Hmmm, yes you are right.... I will ask Mark how he did that and get back to you. I am a hack when it comes to these sort of things :oops: Mark is the cluey one, I just put what info I can on the web page. I think the pulleys came of a Suzuki Swift but I will check that too.
It was delibrate that there were no close ups :-) I did get a bit of warping on the rear pans where I went fairly high up on the sides. I had never brazed before and in hindsight I think I was putting heaps to much heat into it. Anyway I will know better next time. The floor does pop in and out a bit in places but after I am finished doining the sils I plan to shrink the floor a bit to reduce that problem.
PostPosted: Sun May 22, 2005 8:29 am
Yep! He used the Cooper S as he had read somewhere that they have thicker side walls but after doing some checking he recons there is no difference, other than normal variations that you will get from casting and drilling blocks.
PostPosted: Sun May 22, 2005 8:44 am
That'd be good if you could, though I bet a 6-pack of jim beam & colas that Matt will chime in and set me straight :lol: Swift would be good gear to use (I am familiar with Suzuki stuff) as they're pretty easy to get and you can get vernier pulleys too 8)
Dude! MIG is where it's at for that kinda work. Even if you're half decent at oxy welding it's more difficult to keep the heat to a level that wont warp the metal. For a first timer i'd say you did pretty well 8)
PostPosted: Mon May 23, 2005 12:04 pm
Correct me if I am wrong but basicly as far as I know the crank needs to turn 4 times to every revolution of the cam shafts. Engine is a four stroke engine after all :wink:
So as long as the pulleys have a 4:1 ratio you will be right and can grab the pulleys of anything that will fit
The third big pulley is attached to the old mini cam the drive from the crankshaft is below this, incase you were wondering.
I was going to ask before how does it go closing the bonnet on one of these the guy that did the K1 conversion on a 850 said he didn't have very much clearance and a 1275 block is taller than an 850 block right?
Roads need more corners
 Post subject: Thick Web
PostPosted: Mon May 23, 2005 12:16 pm
Not True....later Cooper S blocks had thickened webs...you can see the difference at the front of the engine to gearbox join.
PostPosted: Mon May 23, 2005 2:13 pm
Online
Crank to cam pulley ratio is 2:1.
ie. crank turns twice for 1 cam revolution.
So the cam gears have 2x as many teeth as the crank gear does. 8)
PostPosted: Mon May 23, 2005 2:20 pm
Oppps :oops: :oops: :oops: Two strokes per revolution of the crank that's right.
I was sitting here thinking there are 4 strokes therefore four revolutions of the crank didn't think enough did I :oops: :oops:
Silly me :roll: Thanks Kev
PostPosted: Mon May 23, 2005 4:08 pm
My point was that you're best off getting the cam pulleys AND crank pulley off the same vehicle to ensure that you have the correct ratio. Sure you could muck around getting crank pulley from here and cam pulleys from there but why bother. Get all the pulleys from the one engine and you know it's going to work OK. Then again measuring them isn't that hard. I know what I would do though. :D
One way might be to drop the engine down a bit. Good for centre of gravity, but could cause some ground clearance and driveshaft angle problems. Easiest way would probably be a power bulge.
Sorry, easiest way would be get rid of the bonnet altogether :lol: Simplest legal way would be power bulge. hehe
PostPosted: Mon May 23, 2005 8:31 pm
Jim
Another tip from an old welder (besides grinding the gal for the area to be welded) is to drink plenty of milk, when doing welding on gal we used to be supplied milk by the factory 8)
PostPosted: Mon May 23, 2005 8:40 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i'm perty handy with oxy i used to do alot of it when my dad was alive he said to me when ya can weld with oxy i'll let ya play with the arc welder .... but he was old school was a ground engineer with dehavilan .... pre hawker at bankstown areodrome
makka
PostPosted: Mon May 23, 2005 9:30 pm
makka
If u can oxy well you should be able to TIG like a champ! 8)
My oxy is pretty average, and my TIG ain't much better!!! :lol:
Sure is fun to burn holes in stuff though. And the "screeee!!! screeee!!!" of the grinder!! hehehe, love to make those sparks fly... hehe :)
 Post subject: Mk 2 blocks
PostPosted: Mon May 23, 2005 9:33 pm
The main thing with a Mk2 block is the external vertical rib next to the dipstick hole.This is directly in line with the centre main.(for strength!) Also it is solid below the centre main ,compared to the Mk1 which has a hole. Mk2 has thick bottom flange as well. Dont know about wall thickness.
