It is currently Tue Jul 15, 2025 9:50 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Apr 13, 2015 8:16 pm
There is also heaps of it inside P76s.
Have a Nice Day.
PostPosted: Mon Apr 13, 2015 9:29 pm
Great. :D
So P76's are a good source of supply of this stuff to the Mini community then? :shock:
PostPosted: Sun Apr 26, 2015 8:12 pm
Bubbacluby wrote:
All Leyland minis and clubmans I have destroyed have had the matting glued to the roof turrett. So was common to all slab fronts.
Can't comment on roundies, havnt pulled any apart to check
I have recently stripped the interior of my 67 deluxe and that is exactly what was on my roof turret. Mongrel to get off too!
PostPosted: Sun Apr 26, 2015 10:22 pm
Don't be tempted to leave it out on assembly. If you do, the car rings like a 44 gal drum when you slam the doors!
PostPosted: Sun Apr 26, 2015 11:19 pm
1 Firewall blanket.
2 Between headlining and roof.
3 Under rear shelf.
4 Under spare wheel.
5 Between boot lid and Masonite trim.
6 Under bonnet blanket. (thanks wild_willy!)
And most of it isn't in parts books!
And don't forget the stuff between the dash trim and the upper firewall..... (comes in 4 pieces)
Cheers, Ian
PostPosted: Mon Apr 27, 2015 6:53 pm
Nope it is being replaced with Dynamat
PostPosted: Mon Apr 27, 2015 7:19 pm
I did this once. Driving the car without the deadening in the roof was like driving inside a kettle drum. It was as hot as blazes in summer as well.
PostPosted: Sun Mar 05, 2017 7:13 pm
winabbey wrote:
This afternoon I had an insulation epiphany. :shock:
epiphany - noun epiph·a·ny \i-ˈpi-fə-nē\
: a moment in which you suddenly see or understand something in a new or very clear way
I thought it would be good if we had an unmolested Cooper S to check insulation examples against. My car is a very original 1970 Cooper S but I dismissed it as the mat is missing from under the rear shelf. But then I remembered there were some "spares" that came with the car. I checked a box and, sure enough, the insulation piece was there. :)
I've posted some pictures below (with brick paver background). An Ausmini member friend asked me to post pictures of his MK II Cooper S mat (timber deck background).
Hi Doug
I have just redone my fuel tank breather tubes and refitted the hessian material under the rear seat panel inside the boot. will send you a photo if I can work it out Lol.
The hessian as pictured in your above photo's was in very good order.
Would you know or did you find out the product that the hessian was coated with? (black on under side).
I am in two minds to re coat the hessian or leave it original.
Would you have any leads on where to get some pattens for the lower boot floor and more Hessian.
I'm planing on remaking the fire wall patten as well and I only have some same peaces left of the original.
Any help would be most appreciated.
Kind regards Pete.
PostPosted: Mon Mar 06, 2017 9:48 am
1071 S wrote:
1 Firewall blanket.
3 Under rear shelf.
Cheers, Ian
And the piece between pedal box and parcel shelf.
PostPosted: Mon Mar 06, 2017 2:32 pm
Firefirey wrote:
Hi Doug
Would you have any leads on where to get some patterns for the lower boot floor and more Hessian.
Kind regards Pete.
Pete,
The only technical information I have for the insulation under the rear parcel shelf is that it is 0.5" Rubber Backed felt. I don't know what product it was coated with. Personally I would leave yours as is, depending on condition. Once you play with an item it will never be totally original.
I haven't been able to locate any technical details on size and material for the insulation for the lower boot floor - part 24A81, unfortunately. A possible source of hessian is the underlay when someone is ripping up old carpet. You could try some carpet installers as they probably throw away what they remove.
Is it the internal sound insulation for the firewall (under the carpet) or the blanket that sits in the engine bay behind the master cylinders you are referring to?
Doug
PostPosted: Tue Mar 07, 2017 3:22 am
winabbey wrote:
Firefirey wrote:
Hi Doug
Kind regards Pete.
Pete,
Doug
Hi Doug
Thanks for your reply and yes you right! I will leave the upper boot insulation as it is.
I really do like that original look.
I had it put away in a box for a number years and its in very good condition.
An interesting project to re glue it back in place with the fuel tanks in but it all went really well.
I'm looking at remaking the blanket that sits in the engine bay behind the master cylinders.
I have a small piece of the original blanket that I'm going to try and match.
Would you know of any body who would have an original patten in which I could use?
I'm working on finding some more Hessian/felt as well.
Kind Regards Pete.
 Post subject: Mk 2 S Sound deadening
PostPosted: Tue Mar 07, 2017 5:29 am
Firefirey wrote:
winabbey wrote:
Firefirey wrote:
Hi Doug
Kind regards Pete.
Pete,
Doug
Hi Doug
Kind Regards Pete.
Regarding the firewall blanket from what I have seen the earlier cars had a finer grain vinyl and later 68,69+(??) had the coarser finish v similar to premade ones you get now. The finer grain ones to me look a lot like what may have been used for soft top hoods or ute tray covers??
EDIT. looking back in this thread you will see photos of both types.
PostPosted: Tue Mar 07, 2017 10:14 am
Hi Phillb
Thanks for the info and I have been searching through some of the past chat topics with great interest and this was one subject that I wanted to address.
Would you know of an original patten for the engine bay/fire wall blanket that I could use?
I'm just trying to finish some small detailing on the Cooper S that wasn't finished.
Pete
PostPosted: Tue Mar 07, 2017 12:18 pm
Do you mean shape or the pattern in the vinyl?
PostPosted: Tue Mar 07, 2017 7:50 pm
The shape/ a patten is what I'm after.
I have an old piece with the vinyl on it that I can use to match with some new vinyl.
Users browsing this forum: timmy201 and 98 guests
