It is currently Sat Jun 21, 2025 10:30 pm
Post new topic Reply to topic  [ 230 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 16  Next
 Post subject: Re: 1098 Engine Project
PostPosted: Fri Mar 27, 2015 1:25 pm
The plan is to get the machining (re-bore, head, cam, etc) done and assemble it myself.
We've just finished building a house so money is a bit tight at the moment, and more importantly I do like the process of assembling things and getting them working. I did a very mild standard rebuild on my old Mazda (just rings, bearings and gaskets) and it ran great until I sold it.
That should mean more photos for here, and many more questions too! It's not going to a be particularly quick build, but hopefully finished in the next year.. (Not that I have much to show for the last 10 months!)
PostPosted: Mon Mar 30, 2015 1:16 pm
I've got a hold of a 4 sync gearbox casing. It is missing a few bits so hopefully they'll all swap over from the rod change box. Were the diff covers the same for 3 and 4 sync gearboxes?
PostPosted: Mon Mar 30, 2015 5:06 pm
I believe they are the same Timmy.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Mar 30, 2015 5:45 pm
Yep same, only S ones were much different (had 1/8 bigger bush & seal).
You can also use rodchange covers on remote boxes, but the LH one needs the pointy bit trimmed off its flange.
PostPosted: Mon Mar 30, 2015 6:35 pm
Sorry that wasn't too clear. I should have said diff housing, the alloy bit that holds in the diff.
I've got the diff side covers worked out
PostPosted: Mon Mar 30, 2015 8:28 pm
Yep, still the same. They are a matched set though (gear case & diff cover). Line bored i think.
5/72 Clubman Gt
PostPosted: Mon Mar 30, 2015 8:33 pm
I asked about changing the diff housing a while ago and the doc had a very helpful reply.
viewtopic.php?f=2&t=88564&hilit=diff+housing
Hope this helps.
5/72 Clubman Gt
PostPosted: Tue Mar 31, 2015 10:53 am
Hope this helps.
Yep, thanks for that. I remember reading something about it recently. Did you have any progress getting yours done with the pudding stirrer? I like the idea of that how it looks standard, but I've never driven one with the long stick so I don't know how nice it would be?
I guess you'd need an extra engine steady or two to keep it in check..
PostPosted: Tue Mar 31, 2015 1:36 pm
Danny_ has a 4 synchro remote/puddin' stirrer shift box in his Moke.
It feels very good, now, but I had to build up with silver solder the tin plate's socket where the ball sits then use the die grinder and a ball stone to resize it. Then packed with molygrease.
Before I did this it was like a stick in a bowl of spaghetti (worse than a worn Morris 850 shift). :lol:
Parts for the puddin' stirrer shift are rare now, and apart from John Smidt or `TheMiniMan', I don't know where you would find s/h parts.
PostPosted: Tue Mar 31, 2015 4:54 pm
I think I have one kicking about. The pudding stirrer and magic wand are different housings though, one is a socket into the diff housing, the other is a socket held captive by a retaining plate.
Then there's always the problem, second hand parts are just that, second hand :-/
PostPosted: Tue Mar 31, 2015 5:43 pm
Amazing what worn parts can be reclaimed by hardfacing, brazing & machining, or hard chrome plating.
PostPosted: Tue Mar 31, 2015 6:21 pm
I got as far as rebuilding the gearbox. I measured it all up and it all looks good. Within a couple of thou. Just waiting on some diff parts to complete the rebuild of that and I will then install it.
5/72 Clubman Gt
PostPosted: Wed Sep 02, 2015 2:10 pm
How do these look? Also, will the surface rust be a problem or not? Is there anything I should measure on the old boxes before I pull them to bits?
I've also added another three SU carbs to my collection. I should count them to see how many I have now..
 Post subject: 1098 Engine Project
PostPosted: Wed Sep 02, 2015 2:26 pm
Did you end up getting one of these ?
Found this one in a rubbish pile the other day ! What done people throw out ! Tsk tsk
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Sep 02, 2015 2:32 pm
No, still looking for a diff housing.. What gearbox is that one off, and is the shift rod seized up, or does it move/rotate?
