It is currently Mon Jul 14, 2025 4:19 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 504, 505, 506, 507, 508, 509, 510 ... 568  Next
PostPosted: Sun Feb 08, 2015 2:02 pm
Front underlay and carpet sorted. Door opening alloy bottom strips in. Ignition, lights and wipers switches in. Steering column wiring sorted. Front seats in on their dodgy mounts. Pedal box in for the last time. Accelerator pedal in. Pedal pads on. Shifter boot in. Steering column in and rack U-bolts done up.
The interior just needs seatbelts, dash cluster and dash trims on and it is finished.
M
PostPosted: Sun Feb 08, 2015 2:45 pm
nice one busy day Mokesta
PostPosted: Sun Feb 08, 2015 2:49 pm
M
That much floor work ruins my back!
PostPosted: Mon Feb 09, 2015 9:04 am
trying to find cause for knocking. not sure if suspension related or the unis might be gone
PostPosted: Mon Feb 09, 2015 8:09 pm
New front donuts, old ones stuffed after 7 years! Welded up crack in front subframe tower( due to bottoming out donut).
PostPosted: Mon Feb 09, 2015 8:13 pm
Loving the defender!
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Feb 09, 2015 8:53 pm
Love the hoist
PostPosted: Mon Feb 09, 2015 8:57 pm
Finally got my cylinder head back from the machine shop today!! Fully serviced (had stuffed valve guides and 2 broken valve springs) and a nice port and polish. Bought some nice accessories inc some retractable seat belts. Looking forward to getting her back on the road again!!!
PostPosted: Mon Feb 09, 2015 9:47 pm
Took it for a drive to Canberra
PostPosted: Mon Feb 09, 2015 10:27 pm
Put up the market umbrella so I could work on the mini without melting in the Perth heat.
Started to remove windows but had a lot of trouble with the old rubber trims etc. Got very frustrated but then checked How To Section and found salvation. Phew.
PostPosted: Wed Feb 11, 2015 7:56 pm
Timmy201 gave me a hand with finding my compression ratio on the 1310. Results came up with 9.9:1 which I'm pretty happy with 8)
PostPosted: Wed Feb 11, 2015 7:59 pm
drjbeam wrote:
Love the hoist
+1!
PostPosted: Thu Feb 12, 2015 7:40 am
Mick wrote:
drjbeam wrote:
Love the hoist
+1!
Front support doesnt reach subframe so I've just put it on the most solid point of the sill. Lifted it a few times and it hasnt crushed so at the moment I think its safe that way. Would not mind something to extend it to the subrframe though. but that means the supports will go /\ inwards as opposed to \/ outwards which I would imagine is more stable! so long as the sills dont bend I'll be happy though :lol: :lol:
PostPosted: Fri Feb 13, 2015 9:14 am
replaced voltgage regulator on the back of the crappy 200kph UK sourced speedo
PostPosted: Sat Feb 14, 2015 7:20 pm
I managed to do a little more to my dash.
Just because its Valentine's Day :wink:
11/1973 (Clubman look alike)
