It is currently Tue Jun 24, 2025 1:37 am
 Post subject: 1275 auto diff ratios
PostPosted: Thu Jan 29, 2015 1:01 pm
Hey all, sorry another topic but I thought I would make another one for this specific questions as I'm getting mixed answers.
so I've decided to go for a 1275 and keep it auto in the minimatic. From what I've read here it appears I cannot change the diff ratio in it? is that correct?
I was looking at a rover a+ 1275 auto. Which would probably sit better on a highway.
but at the same time I was offered an a series 1275 that needs a freshen up for a cracking deal.
I was talking to len read and he isnt too sure but he reckons the diff ratio can be changed out? apparently the autos had two ratios they came out with. I forgot the exact he said. 3.1 and 3.2 or 3.3 I think. SOmething lik ethat atleast.
I'm not looking for something to go speeding it. just something that can sit on a highway and not be screaming its head off.
I'm rather tempted to go for the a series (period correct? lol) and hot it up a little bit. If worse comes to worse I cannot change the ratio then so be it. I'll just get to the top speed quicker. But are they indeed changable?
PostPosted: Thu Jan 29, 2015 1:49 pm
from the minimatic website
Differential
In Australia there was only ever one diff ratio in auto boxes. It was about right for a 998cc 700kg Mini on 10" wheels or a 1098cc or 1275cc. A 1275cc auto mini with 10" wheels (or later 12" low profile tyres which are roughly the same outside diameter) will be undergeared and will be quick off the mark, but noisy at motorway speeds. Manual diffs won't fit auto gearboxes.
hmmmmm. so it sounds like there is hope. But not much lol
PostPosted: Thu Jan 29, 2015 5:08 pm
Some one else asked about this. I think there's a 2.9:1 available, or something like that
PostPosted: Thu Jan 29, 2015 5:29 pm
The output ratio of the Matic box has the same revs per 1000rpm as the Mini Deluxe.
There was two different diff ratios in the Australian Minimatic/Morris 1100 Auto.
3.48 in the early cars and 3.27 in the later cars.
The output ratio of the drop gears is 1.15:1.
So that means the 3.27 = 3.76:1.
PostPosted: Thu Jan 29, 2015 5:49 pm
+1 on what Morris 1100 said, so you could try and find an early Morris 1100 auto diff, or buy one from UK and get it fitted.
But having driven minis with 3.76:1 diffs (& morris 1100S, which is 1275, with 4.13, which works out like a 3.76 on a mini), it's really not too bad. Yeah 4000+rpm on the highway, but if the engine is a good 'un they sing pretty well up there :) Still enough rpm left in reserve for a quick squirt as well ;)
cheers,
Jacob
PostPosted: Thu Jan 29, 2015 5:58 pm
You don't want the early auto diff. You want to go the other way with the ratio if possible.
PostPosted: Thu Jan 29, 2015 6:54 pm
The crown wheel and pinion set in an autobox is of totally different design and size to all the manual ones. They are bigger, because the centre spacing of the gears is greater.
The auto's diff output shafts & flanges fit a Cooper S, that's about it for interchangeability.
PostPosted: Thu Jan 29, 2015 9:59 pm
Ahh crapola, brain fade there - yes totally arse about, sorry about that. :|
And yes I should have added the manual & auto diffs are not interchangeable, but the later UK auto diffs should be.
There's a mob in UK manufacturing a lot of parts for these, I'll dig the site up.
cheers,
Jacob
PostPosted: Fri Jan 30, 2015 5:41 am
I posted this in your other thread. Looks like the A+ had the option of two diff ratios
timmy201 wrote:
According to this site the A+ could come with a "2.760" diff (69/25), which should be a bit nicer on the highway?
With the auto 1.15:1 drop gear that'd be about 3.17:1 overall diff ratio
https://www.somerfordmini.co.uk/eshop/i ... age&id=156
Final Drive Gears, Automatic Transmission
22A1003 GEAR, final drive, 72 teeth 3.273:1 ratio (with 22 tooth 22A1300 pinion).
DAM7362 GEAR, final drive, 72 teeth, A Plus type 3.273:1 ratio (with 22 tooth DAM7365 pinion).
DAM4130 GEAR, final drive, 69 teeth, A Plus type 2.760:1 ratio (with 25 tooth DAM4128 pinion).
PostPosted: Fri Jan 30, 2015 6:36 am
Ok these guys in UK stll do parts for mini/1100 autos :
http://www.jpat.co.uk/
Look for "Automotive Product (AP)" as the brand, they have PDF catalouges.
cheers,
PostPosted: Wed Feb 04, 2015 7:33 pm
I spent years looking for a 3.48 diff for my Auto. It would have suited the big wheels of my Moke better.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Feb 06, 2015 10:40 am
Rightyo. I have found myself a a series 1275 auto in Melb.
Len read will be rebuilding it for me. Not sure yet of what diff ratio is in it but he said from what he's seen its higher than a cooper s? dunno. lol
should atleast keep up with traffic better as a start.
Now to decide what mods I want on it.
