It is currently Mon Jun 23, 2025 9:02 am
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Sep 23, 2013 9:30 pm
Archangel007 wrote:
Superturbo - do you mean twin-charge them??
Yes Supercharged and Turbocharged together.
PostPosted: Thu Oct 03, 2013 10:08 pm
The K10 had a super turbo model. March superturbo very rare jdm import ive seen 2 in aus
Sent from my GT-I9505 using Tapatalk 4
PostPosted: Sun Oct 06, 2013 7:58 am
Do it............its absolutely worth it.
PostPosted: Sun Jan 12, 2014 1:10 pm
yep,,, i have 2x 1275cc Micras
one is going to be a willowbank autocross car for my niece (Charnce) for a little while
she might try to take my buggy off me after that :-)
the other one we are stirpping it out now
taking the engine/box & fitting it into my sports sedan for a little while
this will give us a subframe to make a jig tso we can make other subframes
I`m looking at just running the std micra motor in the sports sedan for now but with extractors & Yamaha R1 bike carbs
i will be looking for things like LSD & Hotty Cams & close ratio gearbox along the way
altho i`ve heard all these bits are a bit hard to find, whatever, i`ll just go with what we have for the moment
But,,, with 2x micra engines at my disposal may turbo the 2nd one & have a little bit more fun :-)
PostPosted: Sat Jan 24, 2015 12:36 pm
its happening :-)
in between a few massive heart attacks & a major stroke & looking after my dad & & &
we`ve finally got around to spending a bit of time getting this micra engine transplant started
so,,, we`re doing a couple of them
one is going turbo charged & the other most probably naturally aspirated
i`ll keep throwing pics up as we get more done on them
PostPosted: Sat Jan 24, 2015 1:40 pm
Awesome.
im excited to see the progress
Dusk Blue
1964 850
PostPosted: Sat Jan 24, 2015 11:36 pm
Good work Matt!
PostPosted: Sun Jan 25, 2015 1:44 pm
Great to see Matt, good luck with it all mate.
PostPosted: Sun Jan 25, 2015 2:31 pm
The subframe looks really good. Exciting times!
PostPosted: Sun Jan 25, 2015 2:43 pm
TheMiniMan wrote:
its happening :-)
Question 1: Does that Moke have a drip catcher under it :?:
Question 2: Does the Micra box have reasonably equal length drive shafts (to counter torque steer in a light body) :?:
Onya Matt :!: :D
PostPosted: Wed Jan 28, 2015 12:32 pm
Hee hee,,, the moke has a Bimmer Twinky & doesn`t leak any oil
& the shafts,,,well... one is long & one is short :-) as per usual :-)
we`re not quite half way there but it`s going along quite well,,,still a pile of things to sort out but bit by bit :-)
not much room in there for anything else to fit in there except the turbo & intercooler of course :-)
i can`t see the air-con happening but maybe in a clubby at a later date
Matt
PostPosted: Thu Jan 29, 2015 2:27 pm
Lower/rear mount & bracket
adding some small gussets here n there & a general tidy up before we sand & paint the frame
we have sorted the alternator brackets, just playing around with belts & tensioners now
still have the clutch slave & lever to sort,,, plus a few fiddly things like thermostat housings & such,,, but we`re not far off now
soon we`ll get onto making up the axles & we should be right to whack the whole lot into a car & make it go bruum bruum :-)
PostPosted: Thu Jan 29, 2015 3:53 pm
Matt
Coming along good Matt...will that passenger side rear sub-frame leg be strengthened? :)
PostPosted: Thu Jan 29, 2015 9:04 pm
You'd want it to be - the rear mounts are quite highly loaded.
PostPosted: Sun Feb 01, 2015 1:55 pm
Yes... There is Quite a few more strengthening pieces to go in yet. But very happy with the way it's all been happening. Very strong. Very compact. Very light. Very sexy :)
Users browsing this forum: No registered users and 25 guests
