It is currently Tue Jul 15, 2025 9:32 pm
 Post subject: Baulk rings
PostPosted: Sun Jan 18, 2015 8:18 am
Just going through some parts for my gearbox rebuild and I have 2 different types of baulk rings. One has more cutouts on the cone side than the other. Is one better then the other?
1963 Morris 850
 Post subject: Re: Baulk rings
PostPosted: Sun Jan 18, 2015 1:36 pm
The one on the right is lighter!
"Let us remove your "SHORTS"
PostPosted: Sun Jan 18, 2015 5:47 pm
Oh dear, worry, worry...
Hi Mini0998
The one on the right is a better one to use, and a better design,thats how BMC made the original one's with the little butter fly's on them if I use late model ones like the one on the right I use my little die grinder to cut more slots in them, the original ones had 12 slots in them,but once again it is cheaper to make them with less slots.
Graham Russell
PostPosted: Sun Jan 18, 2015 8:29 pm
Why are the groves good? oil flow?
PostPosted: Sun Jan 18, 2015 8:45 pm
The grooves there are like grooves on a tyre. They displace the oil in between so the baulk ring can grip the gear's cone, essential for gear speed matching (ie no gear grating during shift).
PostPosted: Sun Jan 18, 2015 8:52 pm
Are these grooved the main reason for the preference for the old baulk rings over the new ones?
Oncethe grooves are replicated in the new ones, do they operate more or less identically?
PostPosted: Sun Jan 18, 2015 9:18 pm
GR wrote:
Hi Mini0998
Graham Russell
Thanks for that.
1963 Morris 850
PostPosted: Mon Jan 19, 2015 8:47 am
Mick...I think its more about the quality of the metal faces...which I believe the Doc (for instance) tends to clean up the profile of originals if they are in good condition rather than use the new rubbish.
PostPosted: Mon Jan 19, 2015 10:26 am
The Mini King
The very best Baulk Rings are those with more cross cuts and the butterfly cuts on the outside, as Graham said.
The next best is the ones with more cuts but does not have the butterfly cuts on the outside, then the ones with less cuts but a darker metal, I am yet to be convinced that any of the new baulk rings avail today are any good, my opinion only,
PostPosted: Mon Jan 19, 2015 3:07 pm
If buying new baulk rings, take a gear with you, try the ring's fit on it.
If they rock about in 1 plane (oval) or in both planes (wrong taper angle) don't buy them. By the time they are bedded in they will be worn out.
I have 4 here I bought a while back, can't recall who from (probably in UK), they are so poor a fit I won't use them.
However I have bought some from Karcraft and Minis Plus last year that worked well. On the road... not racing.
PostPosted: Mon Jan 19, 2015 3:57 pm
The Mini King
I buy them from exactly the same supplier as the People you mention above, but I am afraid I do not have the confidence in them that You seem to Have Kev, As I said before though it is only My opinion. I do sell them to people that want New baulk rings, But only after I have advised them of my concerns, I have had New baulk rings in genuine Rover packs that failed in a very short period of time. so when that sort of thing happens it leaves me with some concerns
PostPosted: Mon Jan 19, 2015 6:37 pm
You can extend life of good (not yet worn out) older baulk rings by surface grinding .020" off the face that goes toward the gear. However eventually you run out of good ones and have to buy new from somewhere. As I said in my post above, check the fit of what you are buying. Some are better than others.
If they don't fit right, don't buy them.
PostPosted: Thu Apr 12, 2018 10:08 am
Please identify this unusual marking on the outer side of this baulk ring, there are 6 in total.
PostPosted: Thu Apr 12, 2018 1:53 pm
Would they be the "butterfly" cuts as mentioned above?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Apr 12, 2018 3:17 pm
I think I have rated them correctly.
Users browsing this forum: Dan69s and 99 guests
