It is currently Tue Jul 15, 2025 8:33 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Subframe restoration
PostPosted: Sun Dec 28, 2014 5:04 pm
My attempt at duplication on the rear
This other one I have has two stars (and no surrounding circle), I wonder if you can get a 5 star mini?
they are obviously stamped on after the number.
And I would agree that the stencil is rolled and not sprayed. Took me four attempts to get a semi respectable looking result spraying.
Had another look at my front subframes, have found MOWOG on two of them, one upside down in the center, the other correct way up on LHS.
Roundy Sedan project with/for daughter
 Post subject: Subframe restoration
PostPosted: Sat Jan 03, 2015 3:20 pm
I had the same number stamped on my subframe as you, Frank. From a 68 Deluxe. It had rubber cones when I bought it.
Btw mine was stamped upside-down as compared to yours. And I don't remember seeing any stars stamped on them.
PostPosted: Sat Jan 03, 2015 7:20 pm
"I have never seen a stenciled 'mowog' on a subframe. Its not on the 5 front ones I have."
"Had another look at my front subframes, have found MOWOG on two of them"
Thank goodness we get the correct info out there.
PostPosted: Mon Feb 16, 2015 9:14 pm
Thread revival
'68 wet subframe.
Justin
PostPosted: Thu Feb 19, 2015 8:52 am
I'd just like to add the one on mine looks painted with a roller.
PostPosted: Sat Mar 24, 2018 10:35 am
Old thread, but thought it would be good to keep this all together.
Just out for my restoration of the Mk2 1970 S.
Note the red star, there's another one under the centre jute isolator.
1970 Mk2 Cooper S
PostPosted: Sat Mar 24, 2018 6:53 pm
This one has 21A2159 with blue stars.
What does this number mean?
Have another 2 to check.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Mar 24, 2018 7:19 pm
The part numbers are listed here
http://www.somerfordmini.co.uk/eshop/in ... page&id=68
Users browsing this forum: MiniPete and 88 guests
