It is currently Thu Jul 17, 2025 12:24 pm
 Post subject: Subframe restoration
PostPosted: Tue Dec 23, 2014 6:11 pm
If any Ausmini members are restoring a subframe and wish to add the finishing touch of the "MOWOG" label I have available a plastic template for spraying the name.
Anyone interested just let me know your address and I will mail it out for your use. The only thing I ask in return is that you send it back ASAP after you have finished such that others may make use of it.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
 Post subject: Re: Subframe restoration
PostPosted: Wed Dec 24, 2014 6:09 pm
Awesome idea! I wish I still had mine out! They had a star as well, right?
PostPosted: Wed Dec 24, 2014 7:57 pm
I am doing mine just now and starting to reassemble. I didn't see it before I stripped it. Where does it go?
67 Deluxe under going full resto
PostPosted: Wed Dec 24, 2014 8:36 pm
Ditto "mattywood": where does it go? I have never seen a stencilled Mowog on any front subframe.
There was a part number in yellow on the rear subframe but since it faced into to the floorpan step, it would never be seen.
That is very generous of you John, could you post some pics of where it goes and the finished result
Thanks
PostPosted: Thu Dec 25, 2014 4:55 pm
I think it may have only been early minis that had the white mowog painted on them (like 850 early) happy to be proven wrong
PostPosted: Thu Dec 25, 2014 8:29 pm
This was my rear sub frame with the part number painted onit
PostPosted: Fri Dec 26, 2014 9:04 am
This is off a round nose van
and the star
trying to make a stencil so I can recreate these on the now sandblasted and painted subframe
Roundy Sedan project with/for daughter
PostPosted: Fri Dec 26, 2014 9:36 am
It's a very specific font isn't it.
PostPosted: Fri Dec 26, 2014 10:36 am
Are you doing the front subframe 'mowog'?
I know that my '67 S had it upside down sprayed in white.
PostPosted: Fri Dec 26, 2014 11:22 am
I have never seen a stenciled 'mowog' on a subframe. Its not on the 5 front ones I have.
Photo please someone.
PostPosted: Fri Dec 26, 2014 2:14 pm
As far as I can determine the "MOWOG" was stenciled with white paint on the front vertical face of the front subframe, not sure of the rear though. Whether this stenciling is a later modification I am not sure but the subframe I am doing at present is from an August 1968 car.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
PostPosted: Fri Dec 26, 2014 5:40 pm
There's some good information and a photo on this forum:
http://mk1-forum.net/viewtopic.php?f=3&t=10835
http://mk1-forum.net/viewtopic.php?f=3&t=11217
PostPosted: Fri Dec 26, 2014 5:46 pm
Also on the Mark 1 forum is a thread that suggests the stamped star might indicate what displacers are fitted to the subframe. Presumably the subframes were built up before fitting to the vehicle so that would make sense.
PostPosted: Sat Dec 27, 2014 2:49 pm
Looked to me like the stencils were painted with a roller rather than sprayed on.
Users browsing this forum: No registered users and 72 guests
