It is currently Tue Jun 24, 2025 8:43 am
Post new topic Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 36  Next
PostPosted: Mon Nov 24, 2014 1:18 pm
NT wrote:
Looks like I told a lie then! ;)
Tamiya (particularly TRF) shocks are un-matched in the world of TC to the point that some companies don't even bother trying!
Best quote from the Vic Cup round at Bendigo I heard was 'Change those TC6.2 shocks for Tamiya'.
My touring car, a Spec-R, has shocks that are a blatant Tamiya rip off. I measured every component, and they're identical. This is a good thing.
PostPosted: Mon Nov 24, 2014 1:25 pm
sigh... more money. At least I can get them from Banzai hobby and they'll be cheap and here quick
I did wonder about the carbon v's alloy shock tower too
PostPosted: Mon Nov 24, 2014 1:35 pm
Yeah - the alloy one is probably good for newbs ;)
Buy the TRF shocks - and you'll NEVER have to replace them. You can buy rebuild kits (for about $6 or something stupid) and they are like brand new. That being said - I haven't rebuilt mine in 5 years and they seem to be just fine!
PostPosted: Mon Nov 24, 2014 1:56 pm
n00bs and h4cks alike!
The white bits wear on shocks (I've only replaced the shock shaft guides that are in the bottom), but not any of the expensive bits.
PostPosted: Mon Nov 24, 2014 2:13 pm
So do I need alloy uprights front and rear, or just one or the other?
from the rules, it seems like alloy C hubs aren't allowed, is that correct? the standard screws flop around in the standard C hubs a lot more than I think they should...
PostPosted: Mon Nov 24, 2014 2:23 pm
I don't know about the V2, but on the normal M05 I only run the front. It's to bring the shocks out to be more upright, which is no already the case on the rear.
Tamiya don't make an alloy c hub, so you can't run one.
You want a little slop in a Mini. I've found mine work best after I think they're worn out! My fastest run at Geelong was the event just before I pulled the thing down completely and replaced all the suspension arms, the chassis, and a heap of other bits!
PostPosted: Mon Nov 24, 2014 2:40 pm
Yeah - alloy front mounts only. The rear works as standard - so no need for anything.
If you are talking front and rear knuckles, - then yeah, I run alloy on both ends.
C-Hubs - I don't think I've broken one for years! Alloy ones aren't really needed. Like Scott said, the slop isn't really an issue, they seem to go faster once worn in!
PostPosted: Mon Nov 24, 2014 2:47 pm
boys... "UPRIGHTS", and what about rear toe? what do we like?
54177 aluminium front upright
54178 rear alloy uprights
PostPosted: Mon Nov 24, 2014 3:00 pm
Yep, but just run plastic. I do, well... on the back. I bent my last spare plastic rear upright, so I bent it back to give the right tow. A little reaming and manipulation later it was as good as a new one, and has done 3 months of racing. There's a reason why I have the alloy ones on the front, but can't remember why. Maybe something to do with a low bearing supply issue at the time (I had none in my box). I like plastic uprights, but only when used with 54237 kingpins.
PostPosted: Mon Nov 24, 2014 3:02 pm
Front are definites. I run rears as well. Fronts don't bend in a crash that way. Rear's aren't really affected by crashes - but it's a bit more bling for the fun of it!
1.5deg rears on mine for a bit of stability. You can buy 2deg ones too, but I didn't really notice much difference with them. You can get 0 deg ones too. I haven't run them for years though! Might be something to play with again when I get around to it!
PostPosted: Mon Nov 24, 2014 3:07 pm
Also with the rears, I don't like the suspension pin wearing on the alloy. Could run the c clip style suspension pins and make sure the suspension arms are reamed on the wheel side, and use the grub screw in the upright. I never had the c clip pins so never tried it.
PostPosted: Mon Nov 24, 2014 3:17 pm
what on earth are you talking about??
PostPosted: Mon Nov 24, 2014 3:26 pm
Don't listen to him......he is talking about wear on the hinge pin. You'll wear out the rest of the car before you wear out the hinge pins! ;) Go home Poeee, you're drunk!
PostPosted: Mon Nov 24, 2014 3:28 pm
The only way to get hinge pins is to buy a KIT!
I'm more worried about the wear on the $35+ alloy uprights :lol:
PostPosted: Mon Nov 24, 2014 3:31 pm
You mean the ones I transferred from my 5 year old car to the new one that still beat you? :P
