It is currently Wed Jul 16, 2025 2:24 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 483, 484, 485, 486, 487, 488, 489 ... 568  Next
PostPosted: Mon Sep 29, 2014 10:42 pm
Mick wrote:
Thorlek wrote:
This morning I went to drive to work at per usual, but the Mini would have none of it... not a single sound when i turned the key.
so I took the Territory.
When i got home a few minutes ago... i opened the boot, jiggled the battery cables....
she started up fine.
I guess I didn't hold my tongue in the correct position this morning?
Sometimes they just don't wanna go anywhere.
She was comfortable.
Nick
PostPosted: Mon Sep 29, 2014 10:47 pm
obviously didn't want to go back to work after a 4 day weekend.
i wish i could have done the same and just stayed in bed all day.
1975 Hairy Lime/White Clubby
PostPosted: Thu Oct 02, 2014 11:53 am
Drilled out the water bypass hose on the wrong water pump I ordered, cast alloy so pretty easy to drill. Also knocked up this on the cnc plasma
PostPosted: Thu Oct 02, 2014 1:50 pm
Sump Guard? Noice, how goes the switch plate??
Nick
PostPosted: Thu Oct 02, 2014 2:36 pm
Yep, sump guard it is...No go on that switch panel, not for a while yet. Waiting to get the car painted and start putting stuff back in before I order that. Plus that will be laser cut, notice the sloppy holes that the plasma makes
PostPosted: Thu Oct 02, 2014 2:53 pm
Had it cleaned up
PostPosted: Thu Oct 02, 2014 8:40 pm
Not on the mini but I got a belated present from the wife of a 12T press which is bound to come in handy.
PostPosted: Sat Oct 04, 2014 2:37 pm
Made up a makeshift spray booth and started to prime some more parts for the KProject...
PostPosted: Sat Oct 04, 2014 6:37 pm
I like the booth, will you do the car at home?
Tried to remove the lower channel retention screws from the sliding window doors, and naturally they're jammed in.
So tried to drill them out, but they've work hardened and are making my Sutton drill bits look like pieces of wooden dowel. Grrr...
PostPosted: Sat Oct 04, 2014 8:16 pm
Blocked a couple more panels and cleaned up a few others, now to add a couple of coats of primer in the morning!
PostPosted: Sun Oct 05, 2014 12:38 am
NEW BRAKES WOOO
Nick
PostPosted: Mon Oct 06, 2014 4:05 pm
… well yesterday rather than today…
……...… and I'm not sure I can take credit for "doing it", however definitely I have to take responsibility for causing it to happen….
………………….… and that is sadly killing the heart of my race Mini and causing it to bleed rather profusely :oops:
Dave
1965 Mk1 Cooper S Sprint/Hillclimb/Rally Car
2012 Land Rover Defender 90
PostPosted: Mon Oct 06, 2014 4:09 pm
Dave
I feel for you..:cry:
PostPosted: Mon Oct 06, 2014 4:10 pm
Looks like the 'catch can', didn't. :cry:
PostPosted: Mon Oct 06, 2014 4:27 pm
Refitted the newly skimmed rear drums with an excellent outcome, no more pulsating pedal & no more squeak squeaks!
