It is currently Mon Jun 23, 2025 5:41 pm
Post new topic Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 36  Next
PostPosted: Mon Sep 22, 2014 4:34 pm
I got one of these, don't know how long it'll last for, although I'm not a hard driver. Bang for your buck, it's hard to beat.
http://hobbyking.com.au/hobbyking/store ... ouse_.html
PostPosted: Mon Sep 22, 2014 4:45 pm
looks good... wonder if it would destroy the diff of the M01...
PostPosted: Mon Sep 22, 2014 5:11 pm
I suggest the hobbywing ESC for one on the cheap. Brushed or brushless, I believe they have one for either type of motor. If you buy a radio/remote controller, you should get a receiver with it. Flysky, futaba(one of the better ones) and Spektrum(arguably The Best for pretty much everything RC) all do good cheap radios. You don't really need any more than a 2 channel radio for $50. Batteries really don't matter at all. I haven't seen a NiMh battery bigger than 4200 in the shape that is compatible with the RCs. The batteries that will fit in the M01 are called 6 cell flat packs. Any good one with 4200 capacity can be around $30-40. I wouldn't spend any less than that because it likely won't hold charge. You can buy a cheap wall charger or fast charger for $10 but you can spend a lot more with modes and whatnot for different types of batteries, you can change the Amps and therefore the charge speed. Motors, again are a very grey area. I don't use electric all too much and the ones that I do, I have spent a fair bit on. The only cheap one I can vouch for is the EzRun motor which I have in my mini.
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Mon Sep 22, 2014 5:13 pm
Turnigy are good too. Like I said though, I have never used one. I know they are huge in America.
PostPosted: Mon Sep 22, 2014 6:14 pm
I don't know if M01 has same diff as M03 but if it does, there's this.
http://www.ebay.com/itm/Tamiya-TA03-Bal ... 1081092058
PostPosted: Mon Sep 22, 2014 6:16 pm
Indeed. All the same. I've thrashed mine and my brushless motor is a 13 turn 4750kv motor. I haven't shredded it yet. The only thing I have done is flipped it so violently, the stock friction suspension actually disintegrated in mid air.
PostPosted: Mon Sep 22, 2014 6:47 pm
The gears/diff is pretty strong, most die from lack of lubrication. I don't use the Tamiya AWG, I use the ceramic grease, costs a bit more but just a smidge on wearing bits, lasts for heaps. Don't be tempted to use mineral oils, i.e. engine oil, gear oil, sewing machine oil etc. They're not good for plastic gears but can be used in all metal gear boxes, the big ones, 1/5 1/4 scale etc
PostPosted: Mon Sep 22, 2014 6:50 pm
+1 to that.
PostPosted: Mon Sep 22, 2014 8:25 pm
One benefit of the v2 is the battery holder being compatible with a wider range of batteries.
The turnigy esc/motor combo is good value, but if you ever decide to race you would need http://www.ebay.com.au/itm/like/1714580 ... e&lpid=107
The transmitter I am using is the flysky gt3c. It is good, but avoid the orange ones, they have issues.
The battery I use is a lipo. Most of the guys at our club are using them https://www.hobbyking.com/hobbyking/sto ... duct=25224
However I would use something different if I have the V2
Charger I have is this
https://www.hobbyking.com/hobbyking/sto ... UINE_.html
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Sep 22, 2014 9:03 pm
I was thinking about sticking with the old motor, and getting this to drive it
http://www.hobbyking.com/hobbyking/stor ... r_ESC.html
this transmitter/receiver
http://www.hobbyking.com/hobbyking/stor ... ttery.html
and this battery - it's the biggest capacity 2S I could find that will fit - I have 134mm max
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
will it work?
PostPosted: Mon Sep 22, 2014 9:17 pm
I don't race onroad as I have said and I don't normally use lipo batteries. They have extreme potential though, the amount of power they can provide is astonishing. For my hobao nitro buggy I use a flysky gt2b. I don't need more than 2 channels and the signal strength is great. On my 1/5 I have a futaba 3 channel which cost twice as much. If I really wanted to I could just buy a second receiver and run both cars off it but I wanted to run them at the same time.
PostPosted: Mon Sep 22, 2014 9:24 pm
Yeah that'll work fine. I'd suggest getting a better steering servo aswell though.
PostPosted: Mon Sep 22, 2014 9:29 pm
With that extra power, at least a metal geared servo is ideal.
PostPosted: Mon Sep 22, 2014 9:34 pm
yeah, I have a couple of metal geared servos and a lipo battery charger... I'm just baffled with all of the different terms and acronyms with this stuff... very confusing!
PostPosted: Mon Sep 22, 2014 9:37 pm
I guess ebay is the go for bearings and tyres?
