It is currently Mon Aug 18, 2025 6:49 am
Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29  Next
PostPosted: Sun Aug 31, 2014 9:45 pm
I found a lot of problems with using the mini slave cylinder on the clutch......i actually went cable in the end and it felt heaps better.
Your master cylinder might improve it, but i just found the mini one too short on travel to work properly.
PostPosted: Sun Aug 31, 2014 9:58 pm
Meeni what would you charge to paint the top engine cover? I'm after something that stands out big time. And did you get the picture of the seat mounts in my car?
Life's a garden.... Dig It!
PostPosted: Sun Aug 31, 2014 11:28 pm
Apparently you can get an oem suzuki one but I don't know which car they're off or what they look like.. Il see how this goes anyway. It's firm but not unbearable.
Gordo I have no idea what I'd charge for a cam cover... All depends what you want on there. And yeah saw your seat mounts I reckon I need to do something along those lines.
Potato
PostPosted: Mon Sep 01, 2014 8:46 am
I believe the factory slave cylinder to fit is from a suzuki baleno.
PostPosted: Thu Sep 04, 2014 7:45 pm
Went to pick a part for a look but they were all auto ones.. I can get the slave off eBay it's just the arm that's elusive.
Started on the exhaust. I went and got 2.5" tube for it thinking that won't be too big... It's quite large but oh well.. I'm happy with it although it's a pain to wrap around the gear linkage. Should be fine though will just have to try not to get beeched as bro on speed bumps. I want a 3" outward rolled tip but that's proving hard to find in aus. Sorry about my floor.. It's only like that under the car I promise
I've got some nice things coming to tidy up those fuel and brake lines too... Don't judge me lol
Potato
PostPosted: Sat Sep 06, 2014 8:22 pm
Took the motor back out to do some final additions to the frame. Takes about 5 minutes to get out with the lift up front now which is good.
I did lots of jobs that aren't photo worthy really.. Gussets and strengthening stuff.. Frame needs to come out for final welds and a coat of paint.. Looking forward to that stage so all my time and money. doesn't look like crap anymore. As you can see I've got a small amount of rust to tackle in the crossmember too.
Basic brackets were made for things like the oil catch can
And while the motor was out I welded and painted the crank pulley as well as the water pump pulley
The list of jobs is getting scarily small now I'm worried I might actually finish this and get to drive it!
Potato
PostPosted: Sun Sep 07, 2014 7:48 pm
Today I pulled the frame out and finished it. Not a lot there when the front isn't there
Got some undercoat on it too which was nice
I haven't made the brake line mounts yet but they're going to be bolt on so no need to wait for them.
Potato
PostPosted: Mon Sep 08, 2014 6:17 pm
Looking good.
PostPosted: Sun Sep 14, 2014 7:46 pm
Decided to tackle a couple of mechanical jobs this weekend as I was pressed for time so I got the box and clutch off the motor and put it up on its stand.. Looks a bit grubby il have to re paint everything..
I had a pg LSD to put in so I pulled the gearbox down and fitted that. Nothing looked too bad in there so I just put it back together as is. I won't really know till I run it but should be fine. Bit easier then a mini box..
Potato
PostPosted: Fri Sep 19, 2014 7:14 pm
Been spending a bit of time tidying up the firewall, welding up unwanted holes etc. finally got some undercoat on it today so hopefully I can get some colour on it soon
Thought I'd personalise my gear knob too.. Still needs clear
Potato
PostPosted: Sat Sep 20, 2014 6:34 pm
We have orange
And dark grey
And clear on my knob......... (-_-)
Potato
PostPosted: Sat Sep 20, 2014 8:07 pm
What a difference some fresh paint makes , nice .
PostPosted: Sat Sep 20, 2014 9:37 pm
Sure does. I love it when you get paint on everything.
Potato
PostPosted: Sun Sep 21, 2014 7:34 am
Great knob!
Zulu...
1967 mini Cooper S
PostPosted: Sun Sep 21, 2014 6:57 pm
Bit of re assembly, I've still got to paint the hinge mounts grey but il do that later. Fitted a brand new steering rack, one side of the lower control arms, and mounted the brake and fuel lines that run down the fire wall. Pretty happy with the look of everything so far
All the lines are clamped with billet clamps. Love it, nice and neat
Potato
Users browsing this forum: No registered users and 154 guests
