Kurross wrote:
Thanks for the feedback so far, keep it coming
Whilst I have a thread going, I'll ask a question of you knowledgeable people about the chrome trim. The trim is rolled up atm and I needs to be straightened out, what's the best method for straitening out this trim? oven? hair dryer? or do I need heat gun? (ive seen em pretty cheap at supercheap)
Mark
Hair drier/heat gun could/should technically work, but it's nigh on impossible to do without overheating and melting the trim (IMHO).
Best technique I've found is clipping it onto the steel edge of the gutter on my house. Sunny day, couple hours, job done. Whip it off, onto the car (which has also been sitting in the sun) straight away with no other heat source needed. When it cools it cools to shape so no tension.
