It is currently Sun Jul 27, 2025 7:58 am
 Post subject: Engine Steady
PostPosted: Tue Jul 22, 2014 10:26 pm
Sorry, me again
There has been talk in various threads about how many engine steady's you should have.
I have an 850 with an 1100S engine and Rod Change gearbox.
The only engine steady is the one between the block and the body at the clutch end.
Do I need more and where :|
 Post subject: Re: Engine Steady
PostPosted: Tue Jul 22, 2014 10:43 pm
I only had one at the clutch end of the engine. I kept snapping it.
I now have one either end of the engine and 1 on the gearbox. Engine doesnt move at all.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Jul 22, 2014 11:10 pm
At least fit one on the thermostat too.
PostPosted: Tue Jul 22, 2014 11:13 pm
+1
I had issues with my moke. Needed more support for bad young driving. :roll:
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Jul 23, 2014 9:36 am
The sencond top engine steady was added for the rod change box I think. Every rod change should have one, any movement where the rod enters the box results in leaks.
PostPosted: Wed Jul 23, 2014 9:53 am
It is common to tear the bulkhead crossmember at the rad end when using that top steady.
Best way to reinforce it is to add an empty pedal box on that side.
Way back in the 850 days there were lower steadies available here, they worked fine until oil rotted the rubber bushes.
Top rad end steady is not needed with a remote shift. Cooper S never had or needed it.
PostPosted: Wed Jul 23, 2014 11:48 am
My '73 Mini S came with two and still had the remote change. They must have been phasing them in ready for the introduction of rod change.
PostPosted: Wed Jul 23, 2014 4:35 pm
You can fit four steadies to an engine. 1st at the clutch end going from the block to the bulkhead below the MC's, 2nd is from the thermostat to the top of the bulkhead and like Doc said the best reinforcement/strength is by adding a gutted pedal box (all the holes are there), 3rd and 4th are on either side of the gearbox at the rear going to the subframe.
All can be made yourself or buy them all from most mini suppliers.
PostPosted: Wed Jul 23, 2014 4:46 pm
I think Rovers had a lower one, but it went forward.
PostPosted: Thu Aug 28, 2014 5:16 pm
anyone got a photo of what the one on the bulkhead at the radiator end bracket looks like?
I have the thermostat end mounting and the rod. Just need a photo to make one up.
Roundy Sedan project with/for daughter
PostPosted: Thu Aug 28, 2014 5:42 pm
I don't run any engine steadies.
PostPosted: Thu Aug 28, 2014 6:45 pm
Yeah , but your just LOOSE ! :P :lol:
PostPosted: Thu Aug 28, 2014 6:46 pm
Hardcore morris.... lol
Minis..
1975 van
PostPosted: Thu Aug 28, 2014 6:52 pm
Not my image, stolen from Moke.com.au
Same as 1275LS.
PostPosted: Thu Aug 28, 2014 7:01 pm
Wow thats a pretty engine bay
Minis..
1975 van
Users browsing this forum: No registered users and 112 guests
