It is currently Sun Jun 22, 2025 12:42 pm
PostPosted: Sat Jun 21, 2014 10:22 am
On the Tyre placard on my daughters 04 Cooper S it says recommended tyre size & rim ,
195/55 R 16 87 V --- 205/45 17 84 V .
Does this mean that i can only run " runflat tyres " on this car , because of the "R" , or is it legal to run normal
tyres ?
Has anybody had any experience with this issue ?
PostPosted: Sat Jun 21, 2014 11:00 am
No law states they have to be run flat, just the load and speed rating have to be equivalent or higher.
Just have some finileak or similar.
PostPosted: Sat Jun 21, 2014 1:47 pm
uh pretty sure all tyres have an R there don't they? I don't believe its a runflat thing
PostPosted: Sat Jun 21, 2014 2:07 pm
RADIAL ply
PostPosted: Sat Jun 21, 2014 3:05 pm
205/45-17 is a fairly common size, should have quite a selection.
PostPosted: Sat Jun 21, 2014 3:38 pm
Yep you will notice a much nicer ride with a decent performance tyre, couldnt wait to ditch my first set of run flats
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Jun 21, 2014 7:53 pm
I spoke to a guy at Bob Jane today and he has put plenty of normal style tyres on MINI'S .
With the Yokohama deal on at the moment , ( buy 3 , get 1 free ) i'm looking at my daughter saving some dollars
so that she can re-shoe her car , with decent tyres , at a reasonable cost , so he quoted me a price for Runflats as well as normal style tyres , which works out very good with their current deal .
PostPosted: Tue Jun 24, 2014 11:47 am
Got rid of my run flats in 2005. Had 3 lots of 'high performance' tyres since then, mainly Dunlops. 195/55 will be more comfortable than 205/45. I compromise with 205/50's which are good for regular driving as well as track days. Speed rating and maximum weight loading are important. Your tyre supplier will confirm that for you.
2002 Cooper, when New MINIs were new!
PostPosted: Tue Jul 08, 2014 8:57 am
Thanks for the replies people , my daughter is getting a new set of shoes for it tomorrow ,
Yokohama C Drives 195/55-16 . We opted for the normal type tyre , so we will see how they go ,
best start hunting around for a spare to suit , any ideas ?
PostPosted: Tue Jul 08, 2014 4:56 pm
Little compressor and can of tyre goo, I have a pack that fits into the little cubby hole in the boot.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Jul 08, 2014 5:15 pm
What i had with my 'S' was the compressor / goo pack and a spare 17" wheel at home and an old tyre.
You could get both for under $50 if you're lucky.
PostPosted: Tue Jul 08, 2014 11:06 pm
Got a call from old mate at Bob Janes Newcastle this arvo whilst at work , he tells me that they don't have , and can't get any Yokohama tyres to fit her car :x , because the special Yoki deal that they have had running for a month has cleaned out that particular tyre stock.
He is going to look into what else they might be able to supply for the same money , but i did tell him i didn't want any recycled " Taiwanese Thongs " .
Might have to check out our local tyre mobs to see what they have in stock .
Harley & babes , when you say goo packs , what are they exactly , are they a MINI product , or something
that you have bought aftermarket , like Fineleak?
PostPosted: Wed Jul 09, 2014 8:53 am
Buy it from any auto shop, its a goo you can squirt into the tyre which seals a leak until you get to a tyre shop. Tyre shops hate them as when they take the tyre off they get shite all over their tyre machine.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Wed Jul 09, 2014 9:23 am
Just for insurance, I would check her insurance policy fine print on tyre changes or changes from the original build spec...ya never know!
[no comments about how fitting different brand tyres is common plse...eg "I fitted Michelin XAS to my Datto 1600"...this is about runflats]
PostPosted: Wed Jul 09, 2014 10:32 am
We appear to be having trouble getting 195/55 -16 style tyres , not a common size apparently , I've been ringing around a couple of places to see if anyone has any in stock , no luck .
I've just had a Tyre Dealer mention the Insurance issue again ,basically saying that if the car come with Runflats , that's what we had to put back on it , bearing in mind i'm not changing the tyre size , load or speed rating ,( according to the tyre placard on the car ) , just the tyre design.
I then rang Bob Janes again and was told the same as last time , that you can put normal type tyres on the MINI / Runflat rim , but you can't put Runflat Tyres on standard type rims , apparently the lip inside the R/F rim is a bit taller , this is becoming a PIA !
Good point Mick ,I'm going to check with her insurance to clarify what's real & what's not .
