It is currently Wed Jun 25, 2025 6:23 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 116, 117, 118, 119, 120, 121, 122 ... 125  Next
PostPosted: Fri May 23, 2014 5:35 pm
Give Ash some flowers Nick .
Sorry mate I don't know any sign writers - probably worth the monetary investment though to get your name out there.
If I'm about and not working that weekend I'll help you push it if it isn't quite there!
PostPosted: Fri May 23, 2014 6:47 pm
That is a dream for most. Personally i want to make a turbo hayabusa 4wd. Maybe just go for an engine that no one has ever heard of and make it truly unique.
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Fri May 23, 2014 8:02 pm
Thanks Nick, but hopefully it will be moving under its own steam by then!
Here at TPE, we have a habit of turning dreams into reality!!
PostPosted: Sat May 24, 2014 9:55 pm
Ah mines a decade off. If you're still going then, i'll be sure to get your opinion. :) The new member, Phil850 has a subie powered AWD mini. That certainly sounds appealing!
PostPosted: Sun May 25, 2014 1:58 pm
I'll still be here!! Subie-powered AWD Mini, must go like stink. Any pics??
PostPosted: Mon May 26, 2014 12:50 am
That's what i asked for. No word yet...
PostPosted: Wed May 28, 2014 8:04 am
Still no pics...????
PostPosted: Wed May 28, 2014 3:17 pm
Nothing yet :(
PostPosted: Wed May 28, 2014 8:45 pm
Signwriter suggestion: Graham Griffith of Griffith Graphics in Kelvin Grove.
No idea if he is a good signwriter but he is a great coach to our son's soccer team and a top bloke.
M
PostPosted: Thu May 29, 2014 1:42 am
viewtopic.php?f=23&t=85852
PostPosted: Thu May 29, 2014 5:10 pm
Yeah, just saw it AMM98....thanks for sharing it.
It looks awesome!
PostPosted: Thu May 29, 2014 5:11 pm
M
Thanks Mokesta!
PostPosted: Sun Jul 13, 2014 7:07 pm
Quick Update forumites....
The replacement WMI pump for the one that never arrived showed up at the end of June. With all the stuff going on with Leonidas and also the Ford Prefect hot rod I'm doing, I really wasnt in a rush to put it in. However, last weekend (5-6 July) I got a couple of free hours to myself because there was a bye for Mitch's footy comp seeing as it was school holidays.
Compared to the old pump, its huge. Standard pressure is 200psi, well above the 40psi that the old Shurflo puts out. Apparently it can be cranked up to 300psi, but at that pressure it pulls heaps of amps! At the standard factory setting of 200psi, it still pulls 10amps which is quite a bit on a 12VDC system. The standard pressure is heaps enough to atomise the water/methanol mix into an extremely fine droplet - akin to very fine mist. Here they are side-by-side:
I put an electrical connector onto the pump using a 2-pin Narva connector:
Luckily, the bolt setout for the new pump was identical to the old pump - its kind of an unnofficial industry standard as Shurflo were one of the very early 12VDC pump manufacturers (sullage, bilge and sprayer pumps) so they set the scene with the bolt pattern and everyone after came along and followed suit. I grabbed some 6mm Secure-Torx fasteners from Masters (love Masters!!!) in stainless steel to afix the pump to the alloy plate. That way, it just makes it so much harder for the delinquints to steal the pump without the right socket. Here it is in situ with all the hoses connected and the pump itself connected cable-wise:
Once I finished that, I decided to stay with the boot space and fitoff the license plate light. It comes in from the passeneger side, so I wrapped it in split conduit and passed it through a grommet as it entered the bootlid, then down through another grommet as it enters the light fitting itself.
Fitted off the light itself and voila, done. Still hate the mismatched white but at least it wont stop me getting it on the road. Is it as noticable as I think it is????
That is about it for The Cat, but there is still one more thing to do to the bootspace to finish it off. Hope you like the result....
Tricky
PostPosted: Sun Jul 13, 2014 7:23 pm
hello Tricky
Ive been keeping tabs on this build for 2 years now. Man this thing is cool, Hats off to you Bro!
When will you get to turn the key and fire this cat up?
PostPosted: Mon Jul 14, 2014 3:19 pm
Hi Mate,
Dont know for sure but I would like it to be this year.
Unfortunately, I have so much work on its hard to put time aside for The Cat.
But as they say, 'little by little, bit by bit'....
Tricky
