It is currently Tue Aug 19, 2025 4:45 am
Post new topic Reply to topic  [ 213 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 15  Next
PostPosted: Wed Apr 02, 2014 7:36 am
Me likely to see progress! Good work mate!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Apr 06, 2014 7:31 pm
Okay so we're back in action with this thing - I bought a welder the other day (up until now I've been borrowing them) so nothing was holding me back to do a few jobs.
First one was to get the alternator mounted:
Then I set about installing the radiator. It was going to be side mounted but this way has more room.
See - plenty of space for a fan. :D
PostPosted: Sun Apr 06, 2014 7:59 pm
How will you run the top radiator hose?
PostPosted: Sun Apr 06, 2014 8:23 pm
The top and bottom hose connections will be blocked off, and moved to the other side.
If I put the radiator in without mods then the cap would hit the bonnet, the lower hose connection would hit the engine mount and there wouldn't be much room for the top connection.
PostPosted: Mon Apr 07, 2014 12:15 am
with the rad in front my turbo may infact fit :)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Apr 07, 2014 9:24 am
Except theres no room between the engine block and the radiator to run your exhaust through.
PostPosted: Tue Apr 08, 2014 5:49 pm
tilt the motor back a bit? intake looks like it has some clearance to the crossmember...
PostPosted: Wed Apr 23, 2014 11:26 am
With the four day weekend just gone, I managed to spend every day of it in the shed.
The subframe is now ready for paint, the clutch setup is working nice and smooth, and I've filled and repaired a bit of the engine compartment panels. Just got to tidy up the cut edges around where the frame fits.
PostPosted: Fri May 02, 2014 11:20 am
PostPosted: Fri May 02, 2014 11:25 am
That's a decent sized boot/ hatchback. Does look good!
Life's a garden.... Dig It!
PostPosted: Fri May 02, 2014 7:42 pm
Like!
PostPosted: Fri May 02, 2014 10:26 pm
Looks good in white!!
PostPosted: Wed May 21, 2014 9:52 am
Looks even better red!
:D
PostPosted: Wed May 21, 2014 11:03 am
Looks great in any colour
What's the go, did you powdercoat it and then paint it or something?
Or is that just really white primer?
You're so square
Baby I don't care
PostPosted: Wed May 21, 2014 11:18 am
Just industrial zinc epoxy primer after the frame was blasted, I was surprised how light it was too.
Made painting easier though.
Users browsing this forum: No registered users and 187 guests
