It is currently Fri Jun 20, 2025 10:52 pm
 Post subject: ABS Amber Light
PostPosted: Wed Jan 29, 2014 8:07 pm
My daughters 04 Cooper S has the ABS light on all the time , any ideas as to where to start looking for the problem , or is it a computer hook up to find the fault ?
 Post subject: Re: ABS Amber Light
PostPosted: Wed Jan 29, 2014 9:26 pm
Check that none of the wheel speed sensors are damaged. Should be a sensor on each hub and just check the wiring from the wheel to the inner guard. If they are all plugged in and don't look damage then you will probably need to get it scanned.
Alternatively, go down the road and stand on the brakes. If there is a problem with one of the wheel sensors that wheel should lock up.
PostPosted: Thu Jan 30, 2014 3:52 am
Thanks for that Matt , will check it out .
PostPosted: Thu Jan 30, 2014 6:27 pm
Alternatively, go down the road and stand on the brakes. If there is a problem with one of the wheel sensors that wheel should lock up.[/quote]
If you try this method all the brakes will lock up
If the ABS light is on the system is disabled the brake system go's back to a normal non ABS system
You will need to scan the ECU with a scan tool
Don't under estimate the power of a Mini
1975 Supercharged Blue Mokezilla ;)
1976 Fudge Moke
1967 BRG & White 67 Morris Deluxe
1974 Clubman Mini S
2005 Red Mini Cooper S
2009 Mitsubishi Outlander VRX
PostPosted: Thu Jan 30, 2014 7:30 pm
Ok so i haven't played with MINI abs but i have played with the new suzuki swifts. I do quite a lot of work on the race cars in the australian swift series and as they are constantly crashing etc so they often damage the sensors. We often test the cars out and even though the abs light is on, it is only ever the faulty wheel that locks up, all the rest work as per normal.
PostPosted: Fri Mar 14, 2014 12:54 am
Brake pads sensor. check that your front brake pads are nor worn out.. IF they are, you have to replace the pad sensor
PostPosted: Sat Mar 15, 2014 8:38 pm
Doesn't that turn on the brake warning light (handbrake, low fluid etc) not the ABS light?
