It is currently Thu Jun 26, 2025 10:08 pm
 Post subject: Clubman 1976 Gearbox
PostPosted: Sun Feb 02, 2014 4:51 pm
im not to happy with my gearbox and want to get a new one built.
works fine 1 2 3 4 going up and good 4 3 going down but have troubles sometimes finding second at hi revs.
who should I get to build me a box anywhere from Wollongong to Sydney, what should I get in it to make it a strong street box, what is the going rate for a full rebuild and what should I look out for?
I have a spare gearbox I can get my hands on to rebuild so I can still drive my car around do they all fit or do I have to find the write one for my engine?
 Post subject: Re: Clubman 1976 Gearbox
PostPosted: Sun Feb 02, 2014 7:17 pm
In your 76 mini it should have a four speed syncro, rod change box.
You'll need to check what the numbers are on the gearboxes, they should be cast into the housing behind the oil filter. The numbers could be DAM3220, DAM2686, DAM2886, DAM4818 or DAM5626.
Check the numbers on your gearbox and let us all know what you have, also check the numbers on the other box to see if they're compatible.
PostPosted: Sun Feb 02, 2014 7:27 pm
A/BZ3
BC&M
22G1832
PostPosted: Sun Feb 02, 2014 7:36 pm
That should be a 4 syncro box, (in the book I'm looking at that's listed as the idler gear but it's still in the same spot).
PostPosted: Sun Feb 02, 2014 7:51 pm
What did it come off ?
PostPosted: Sun Feb 02, 2014 9:08 pm
The gearbox? it probably is the orgional one for your car but it's a common box, pretty much every mini from 74 onwards had one.
PostPosted: Mon Feb 03, 2014 7:59 am
All ive been told from the gearbox im getting is SM1032.
ill get more info when I pick it up
PostPosted: Mon Feb 03, 2014 1:15 pm
that's an 1832 box.
PostPosted: Mon Feb 03, 2014 1:32 pm
What did this come off ?
PostPosted: Tue Feb 04, 2014 12:10 pm
Leyland Mini or Leyland Moke.
edit; check diff ratio to confirm which.
PostPosted: Tue Feb 04, 2014 2:36 pm
Count the teeth on the pinion, no need to pull the diff out.
15T = Moke,
18T = Mini (there may be some Mini rodchange boxes used in Oz with a 17T pinion, but I've never found one).
PostPosted: Mon Feb 24, 2014 6:14 pm
15T = Moke,
What is the pinion ?
PostPosted: Mon Feb 24, 2014 6:26 pm
The pinion is the small gear on the end of the mainshaft, the one inside the gearbox closest to the speedo, not the one that hangs out the end. It drives the crownwheel which is the big gear bolted onto the differential.
The number of teeth on the crownwheel divided by the number of teeth on the pinion tells you the final drive ratio.
PostPosted: Thu Mar 06, 2014 6:25 pm
The Gearbox in my mini
A/BZ3
BC&M
22G1832
how do I know if is a remote box or not ?
PostPosted: Thu Mar 06, 2014 6:30 pm
Can I rebuild this box for my engine?
AS I NOW HAVE ANOTHER SPARE
W 22A1522
SM MOWOG
