It is currently Thu Jun 26, 2025 6:14 pm
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13
PostPosted: Tue Dec 17, 2013 9:28 am
chrysler1969 wrote:
any one got bens contact details ??
pm user '92'
PostPosted: Wed Dec 18, 2013 8:48 am
Im thinking of selling my sc12 kit and charger if anyone is interested. You'd need to source the lower pulley, upper engine steady and hif44 as im leaving them on but the rest is there.
PostPosted: Sat Jan 11, 2014 3:31 pm
do you need to get the sc12 kit engineered?
67 Deluxe under going full resto
PostPosted: Sat Jan 11, 2014 5:56 pm
You will most probably need a mod plate, so yes.
PostPosted: Sat Jan 11, 2014 6:01 pm
It was hard enough finding these parts 10 years ago.... id hate to try find a SC that hasnt been thrashed today..
Sent from my SM-N9005 using Tapatalk
PostPosted: Sat Jan 11, 2014 6:07 pm
I have some.
PostPosted: Sun Jan 12, 2014 7:30 pm
Hey Guys,
Picked up a rebuilt SC12 on Friday which will be going on my 1275LS engine.
What are some recommendations for compression ratio etc?
My plans are currently:
1293 GR pistons
Wade 240 cam
Modified head to suit sc12
Standard crank and rods
Straight cut gear box and x pin diff
I'm wanting to run about 8 psi and be putting out something a bit over the 100hp mark.
Any help is appreciated as I'm new to building engines and need all the help I can get.
Cheers, Rhys
1977 Leyland Mini Van - Sold
PostPosted: Sun Jan 12, 2014 10:53 pm
Do you have any details on the rebuilt sc12? As to what was rebuilt/replaced? Asking because as far as i am aware parts aren't available.
As for the engine, I'm building mine at 9:1 comp ratio which i think is on the high side of things. When i say 9:1 though i mean i have accurately measured everything. I have megajolt working so i can set the advance curve easily.
For my engine i left the pistons standard height, just 1 head gasket but i made 30cc chambers in the head, so you will need to decide which way you go to get the cc's
And the big question, what do you want to do with the car?Road or race? I would use a standard box with a lsd over straight cut regardless.
PostPosted: Mon Jan 13, 2014 5:54 am
What about brakes?
PostPosted: Mon Jan 13, 2014 9:18 pm
mattywood wrote:
What about brakes?
Most proably 7.5" disc brakes, but to be sure contact a local engineer they will be able to fill you in on all the finer details.
PostPosted: Tue Jan 14, 2014 5:12 am
thanks
PostPosted: Tue Jan 14, 2014 3:25 pm
Regardless of legal reasons, it would be a very good idea to upgrade brakes
PostPosted: Tue Jan 21, 2014 3:57 pm
If Ben makes a sprintex version is that manifold compatible with the Easton M45 because you can pick them up cheap. Or is it more economical to stick with SC12 if you can't stretch to sprintex?
