It is currently Fri Jun 27, 2025 2:22 am
 Post subject: Clubman Half Roll Cage
PostPosted: Thu Dec 12, 2013 7:43 pm
Hey Guys
just wanted to know if anyone is running a street Car with a half roll cage.
1- is it legal due to the age of the car?
2- who makes them in Australia or do I have to go custom?
3- Anyone have any Pics of there set ups?
PostPosted: Fri Dec 13, 2013 1:43 pm
Hey Micool,
I don't have a half cage but have been looking into it.
I know in WA a 4 Point Roll Cage is legal in any car, although an application for modification needs to be made to the Department of Transport and approved prior to modification. The car then has to go over the pits to check the modification. I don't think it's required but the few people I know who have put a 4 point in their car (Sil80, RX7, S15) had the rear seats and rear seatbelts removed and had the car changed to a 2 seater.
I've been quoted here in Perth around $1200 for a custom weld in CAMS 4 point cage with harness mounts. I think Bond Roll Bars do a half cage (4 point) and also a full cage (6 point? with removable intrusion bars). It was awhile since I spoke to them but I'd say they still do it.
Hope this helps mate.
Keels.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Sun Dec 15, 2013 10:48 am
they still do them
PostPosted: Tue Dec 17, 2013 3:11 pm
found a company in Wollongong called pro fab that can make a custom one.
PostPosted: Mon Jan 06, 2014 1:33 pm
micool wrote:
Hey Guys
yep, not in the mini though (cramped enough :D )
you'll find on older cars/pre ADR stuff, not only do we have much more latitude in the things we do to them, that you won't get pulled up for it (prob for that reason...), police tend to leave classics alone.
welded in halfcage (two seater so no problem)
bolted in halfcage (originally 4 seater so bolt in only)
PostPosted: Tue Jan 07, 2014 5:48 pm
http://www.rms.nsw.gov.au/registration/downloads/vsccs_faqs.pdf
Can roll cages be used in vehicles as long as they
are designed and constructed properly?
Roll cages can be used in vehicles provided the
installation meets the applicable vehicle standards.
Installing a roll cage has the potential to affect one or more
Australian Design Rules (ADRs), in which case
certification will be required.
The relevant standard is the requirement in Clause 21 of
Schedule 2 of the Regulation that everything in a vehicle’s
construction and operation must not pose a danger to any
person.
Four-point roll cages can still meet this requirement,
however six-point roll cages cannot because the
configuration of a six-point roll cage creates a rigid item
directly in the head-strike area and obstructs the driver’s
vision through the windscreen and adjacent side windows.
A six-point roll cage may be installed in a vehicle if the
front part is removed when the vehicle is used on a road or
road-related area.
Guidance on the fitting of roll cages can be found in
Section LK of VSB No.14.
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP7_Section_LK_Seating_and_Occupant_Protection_1Jan2011_v2.pdf
PostPosted: Wed Jan 08, 2014 8:38 pm
I have a 6 point cage in one of my street cars however it was engineered 10 years ago when laws were different. I still had to have it engineered as it is now registered as 2 seater because of the two rear arms that go to the parcel tray render the back seat useless. It's a bolt in cage with a diagonal brace behind the front seats.
www.facebook.com/sydneyminis
www.facebook.com/miniowners
www.sydneyminis.com
1969 Morris Mini K- 1380cc for driving
1969 Morris Mini K Panel Van- 1098 for loads
1971 Morris Mini K Panel Van- Still in the barn
2000 Rover Mayfair- Luxury
PostPosted: Fri Jan 10, 2014 11:08 am
Don't wont to go as far as 6 point still want to have the rear seats in it.
there is not many pics on the net.
PostPosted: Fri Jan 10, 2014 12:36 pm
I've got a half cage in a round nose with access still for rear occupants, l don't know the manufacturer though
1993 R32 Nissan Skyline GTR
PostPosted: Fri Jan 10, 2014 12:58 pm
are you able to post some pics for me mate ?
PostPosted: Fri Jan 10, 2014 2:42 pm
Not really a 4 point sorry but anyway
PostPosted: Sun Jan 19, 2014 7:50 pm
alittle more info on your setup - keen on something exactly like this :)
Custom made or kit ? Where from / cost ?
PostPosted: Sun Jan 19, 2014 8:25 pm
Sorry mate came with the car, no branding on it
