It is currently Tue Jun 24, 2025 12:13 pm
Post new topic Reply to topic  [ 236 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15, 16  Next
PostPosted: Mon Oct 21, 2013 6:28 pm
At least the dash on a mini is reasonably simple
Life's a garden.... Dig It!
PostPosted: Mon Oct 21, 2013 6:30 pm
Die Die Die!!
whats taken the most time with the dash is having to drill the holes, and find all the nuts and bolts,
im almost there, just need to go get the 4x speedo cluster to firewall bolts that go into the captive nuts
then it should all bolt up :)
PostPosted: Mon Oct 21, 2013 7:39 pm
Give Ash some flowers Nick .
Yummy progress.
That colour looks more fantastic the more I see it.
PostPosted: Tue Oct 22, 2013 4:36 pm
Die Die Die!!
did a little bit more today,
installed the headlamp bowls and headlights, and front indicators, the pinch weld on the front grill
and installed part of the brake and fuel lines
decided to take a happy snap to get me excited, its feels so close now
PostPosted: Tue Oct 22, 2013 5:55 pm
Coming along nicely, and I agree with Nick, the colour looks great!! '
Well done!
Tricky
PostPosted: Mon Nov 04, 2013 9:54 am
Die Die Die!!
just a brief update,
waiting for a wiring loom from Vinwire so i can start splicing them together,
also waiting for a harmonic balancer to arrive from adelaide as mine was no good
untill i get these theres not alot happening,
however i did receive some goodies today,
got my new fuel sender
and also my 13x7 mamba wheels
PostPosted: Mon Nov 04, 2013 7:02 pm
Looking forward to seeing a pic of the wheels when they're on
I'm all for mokes on 13 x 7's
PostPosted: Mon Nov 04, 2013 7:33 pm
_666_ wrote:
Noooooo, Always been a fan of the Mamba. Going to have to change my mind, yet again, on wheel choice!
PostPosted: Mon Nov 04, 2013 7:35 pm
Die Die Die!!
the photos don't do them justice, they look fantastic in person
PostPosted: Tue Nov 05, 2013 5:42 pm
Die Die Die!!
had some time on my hands today so i went out a bought a Dremel,
decided to try and attack my corroded old alternator..
it didnt work too bad but not quite as good as id have hoped
PostPosted: Thu Nov 07, 2013 8:17 pm
Die Die Die!!
work on the moke has been a bit slow while i wait for the loom to arrive,
the harmonic balancer arrived though so i can get started on the engine at some stage
but today my attention was on the daihatsu gauges,
the stock gauges stuck out too far for what i need, so my idea is to get a peice of perspex and modify the guages so they are more flat,
i seperated the facia and the bezel from the gauge
then started to trim down the black bezel
then i trimmed a piece of cardboard to get a rough idea of the size i need to cut the perspex
then i cut the perspex and at the moment im in the process of sanding it down to fit nice and snug within the edges of the bezel
PostPosted: Sat Nov 09, 2013 7:37 pm
Die Die Die!!
so after alot of sanding ive finished the slimline dash,
im a little unhappy with the way the glue set on it (looks a little messy) but hopefully ill make up some sort of bezel for the dash so it will hide it :)
i also have some plans in the mix to make a custom dash for my moke so stay tuned for that..
PostPosted: Mon Dec 09, 2013 9:15 pm
I saw you bought a new mini. What's happening with this build? Is it still on the go?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Dec 10, 2013 10:00 pm
Die Die Die!!
hey ryan, its still on the go, just been waiting an eternity for the wiring loom from VINWIRE,
probably dont see it being finish now untill late february
PostPosted: Thu Dec 12, 2013 8:38 pm
Die Die Die!!
the engine loom arrived today after about 5 weeks waiting for it, so ill get stuck into the moke over the xmas period and hopefully have most of it ready to go to the auto elec in january to get the loom spliced
