It is currently Sun Jun 22, 2025 2:25 pm
 Post subject: Fuel Line Return
PostPosted: Mon Oct 21, 2013 11:49 am
Die Die Die!!
i believe i need a return line for my sirion conversion,
do i need to install a return pipe to my tank or can i just pipe the return line back into the main line, or into a swirl tank ?
Nick
 Post subject: Re: Fuel Line Return
PostPosted: Mon Oct 21, 2013 12:20 pm
Back to one of the tanks is the best place, probably the main one. Don't just let it flow into the top - it'll airate the fuel.
PostPosted: Mon Oct 21, 2013 12:30 pm
Die Die Die!!
So it's best to pipe it to a swirl tank or well in a return fitting, I can't put a "T" fitting into the main line ?
PostPosted: Mon Oct 21, 2013 12:58 pm
You can't do that, if you could then there wouldn't be a return line at all.
Some new cars only have one fuel line, but that's because the pressure regulator is in the pump, not the fuel rail like yours probably is.
PostPosted: Mon Oct 21, 2013 1:16 pm
you can as long as its before the pump, your fuel will get hot though
I only have one fuel line, I don't have a regulator in the pump AND I return into the top of the tank :D
