It is currently Sun Jul 06, 2025 9:00 am
PostPosted: Mon Oct 14, 2013 5:38 pm
I'm having trouble with a door lock on a 1968 Cooper S (Aus model with wind up windows)
I purchased a handle/lock assembly without a key and I'm trying to remove the lock barrel so I can get the parts re-chromed. I've removed the split pin etc but unable to remove the barrell.
Any ideas?
Ian
PostPosted: Mon Oct 14, 2013 6:04 pm
You need the key to remove the barrel from the handle
have a look on the square shaft and see if there is a number stamped
this number will be the key number , which can be cut from a set of master keys
or a locksmith may be able to remove it for you
Mark
PostPosted: Mon Oct 14, 2013 6:11 pm
Mark
As Slacko says the lock must be undone to get it apart.
I took my spare handle to Mini King and trawled through their collection of keys until I found one that fitted.
PostPosted: Mon Oct 14, 2013 6:21 pm
You don't have a location in your profile
it is really helpful if people know where you are , as many may be in your area,
and you will find many willing to help
Cheers Mark
PostPosted: Mon Oct 14, 2013 9:22 pm
I got a new (2nd hand) door handle and barrel which didn't have the key and was locked... used a piece of wire and a small screwdriver to unlock it, took about 5 minutes of jiggling and i've never picked a lock before (i swear officer! hehe)
There's only 5 tumblers in the barrel from memory and it's not the most accurate style of lock. If you're local in sydney i can have a crack at it for you or you could just do as the other guys have mentioned and get a key cut to match your lock.
Having seen first hand how easy it is to get around these locks it's definately worth having a cutout switch or immobiliser of some sort!
PostPosted: Wed Oct 16, 2013 7:16 pm
Great, thanks guys will give it a crack ( :D ).
Ian
PostPosted: Wed Oct 16, 2013 7:18 pm
Don't post on a forum what security features you have on your car.
Crooks read this forum. Some of them have even been known to post here.
PostPosted: Wed Oct 16, 2013 9:42 pm
The early locks are usually knackered by now, you rarely need anything sophisticated to pick them, in most cases any Mini key will open them with a bit of jiggling.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Apr 13, 2020 2:32 pm
I would like to remove the drivers side key barrel but the above is of no help.
Is there a way to remove the barrel?
I do have the key but would to replace all the locks with the same barrel.
PostPosted: Mon Apr 13, 2020 3:17 pm
Knock the retaining pin out of the hole you see here close to the handle itself. The pin is out in this shot.
PostPosted: Mon Apr 13, 2020 9:10 pm
Here’s a link to how I changed my locks
viewtopic.php?f=2&t=92574
PostPosted: Tue Apr 14, 2020 8:59 am
This is impossible if you do not have a key to remove the escutcheon first.
PostPosted: Tue Apr 14, 2020 11:53 am
Ah, OK. I thought the pic of the handle above without escutcheon was yours. So yes, you need to have the lock picked to advance your work. If you can find someone with a supply of keys you will probably find one that opens the lock even though it is not the original key code. The locks wear sufficiently to enable that to happen in many cases. Otherwise it's off to a locksmith.
PostPosted: Tue Apr 14, 2020 4:11 pm
I'm not totally sure with Minis but with a lot of automotive locks you don't need the correct key to remove the lock, you just need a key, any key that fits the hole.
PostPosted: Tue Apr 14, 2020 5:35 pm
Morris, on a Mini you need to turn to unlock to retract the plunger or the escutcheon won't fit over it.
Users browsing this forum: 748rum and 91 guests
