It is currently Sun Jun 22, 2025 7:59 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Sep 16, 2013 7:21 pm
_666_ wrote:
You only get charged duty for goods over the value of $1000 AUD
Well sometimes you do :D Depends how far over 1k you go. My last order of $1400 went through no problems, just a matter of luck sometimes..........
PostPosted: Mon Sep 30, 2013 10:42 pm
Die Die Die!!
How are you getting on with it ? Can we see some pics ?
PostPosted: Tue Oct 01, 2013 3:19 pm
if you are referring to me
viewtopic.php?f=3&t=82960
PostPosted: Wed Oct 02, 2013 9:55 am
Die Die Die!!
Do you intend to modify the intake header by welding or by hose and clamps, or will you cut the firewall and box it ?
PostPosted: Wed Oct 02, 2013 11:36 am
Hopefully the clubman has more room - the engine mounts are 15-20mm adjustable back n forth too.
I will cut as much off the underside of the inlet manifold as I can, but
If it's too difficult I'll consider quad throttle bodies instead of cutting and welding the firewall
