It is currently Sat Jun 21, 2025 6:57 pm
 Post subject: got my diff fixed
PostPosted: Thu Sep 05, 2013 6:49 pm
some of you may know that the diff in my buggy has been stuffed for the last few meetings
so we got it out , gave it back to Freddy & he`s replaced a split cone,
packed/shimmed it all back up nice & tight again (45lbs-ish)
so now it`s back in it`s little cradle & ready to go back into the buggy :-) Yippy :-)
so i thought i`d take a quick snap of it to show you all
Oh & i fitted a brand new 530 X-Link O-ring chain on it now too :-)
i like to spoil my buggy i love her that much :-)
I reckon i`ll be buying a tran-x diff soon tho
anyways,,, next meeting is the day & night autocross at willowbank on Sat the 21st of this month & the very next day 22nd (sunday of course) the Big track Sprint meeting is on
so 2 days in a row of wicked buggy autocross action with my new diff & new chain
cant wait :-)
 Post subject: Re: got my diff fixed
PostPosted: Sat Sep 07, 2013 8:06 am
& now it`s back in & running again . Yay!!!
PostPosted: Sat Sep 07, 2013 1:13 pm
Looks good Matt.
PostPosted: Sun Sep 08, 2013 10:21 pm
Well done Matt, but when are you going to turbo-charge that thing??
PostPosted: Tue Sep 10, 2013 7:16 pm
Nah,,, going turbo charged suzuki hayabusa mid engined 4x4 in the next frame buggy :-)
400hp,,, 4 wheel drive ,,, & 400 kgs
PostPosted: Wed Sep 11, 2013 12:41 pm
I'll drive!! :mrgreen:
PostPosted: Fri Sep 13, 2013 11:44 am
You drive, il crap myself.
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Sun May 24, 2015 2:27 pm
ok,,, soooo,,,, after 3 diffs shredded now,,, 2 of freddys & one quaife
i`ve decided to rip a few "other" diffs out of stock & have a play
i`m currently in the middle of setting-up a salibury (Plate type) diff
it was looking like i may have had to creat a new (different design) cradle to fit the salisbury in
but i`ve just spent a few hours here at the shop this morning having a good look at things
it`s easier than i first thought,,, no need to change the cradle at all
2x 35mm go-kart axle bearings & their alloy mounts & we`re done,,, i can bolt it all back in after swapping the potty axles out for early splined Hardy spicer type assys :-) :-) :-)
it`s funny as because it looks like the circlip on the inner axle falls neatly & nicely inbetween the 2 go-kart axle bearings,,, the distance is right,,, the small gap between the bearings is just right for the circlip,,, it`s almost like it was meant to be :-)
I`ve bought a larger (44tooth) sprocket & machined it to fit the salisbury, i have our machine shop ready to make a mounting plate to bolt the new sprocket onto the diff
just sort another orange juice tin to cover it all & hold the oil in & we`re away
choofed i am :-)
i have new alloy front hubs now,,, new 4-pot alloy calipers.
i have new alloy body shocks (twin adjustments) with titanium springs coming
taking the huge alloy 30 litre fuel tank out, replacing it with a small alloy 2litre one, i can do away with piles of weight from all that fuel & extra pump etc.... i`m taking the wings & brackets off the thing,,, i`m cutting big holes everywhere through the space-frame,,, i have Dale (my metal fabricator) making up some chrome-molly rear trailing arms,,, fitting small go-kart discs & alloy Norton bike calipers onto the back of it instead of all the moke arms & cast iron drums & backing plates & shoes & cyls etc etc
i`m ordering some titanium drive flanges foir it soon & maight even fork-out for some titanium axles while i`m at it :-)
i will save (possibly) about 50kgs once it`s all done,,, add to that the zippy-er f/d ratio (Larger rear sprocket) ,,, also the new shock/spring package is half the weight
it`s almost like i`ll be taking one complete front & one complete rear wheel assy off the car in weight, plus removing so much other stuff ,,, 50kgs,,, can you even imagine what a loss of 50kgs will be like in this thing ???
add the sticky new Hoosier-daddy slicks & tighter diff & better dampners & stiffer springs & & &
Like the good ol Colin Chapman from Lotus used to say "If you want to go fast,,, just add less weight"
i heard a story from a few people years ago suggesting that Colin Chapman used to say that-> "design & build a very lightweight, high performance race car,,, designed with the best ideas,,, built with the best & lightest components & material,,,, then once it`s finished,,, take out half the materials" :-)
so, here`s a pick of a few diffs i have here, Pall type,,, & 2x salisbury types, with a few sprockets i`ve been playing with
so,,, once i`ve finished all that change-over stuff,,, diff, shocks, springs, wings, fuel tank, tyres etc etc etc,,, add the new 10"x8" slicks for the hillclimbs & street sprints
& when i go to the big tracks like Lakeside & Morgan Pk etc,,, i`ll just add big 13"x10" slicks tyo get the gearing tall enough for the top-end long straights :-) easy enough to do at the workshop before i go,,, then swap the 10" slicks back on the for the hillclimbs... easy-peasy
i`m sorry for the long winded explanation here, but i`m so happy it`s looking so easy to swap diffs,,, i`ve been pondering this swap-over for a long while now & feared that i`d have to make a new cradle,,, took me ages to get the first cradle right :-) & looks like i can still use it for this new diff so i`m really really stoked :-)
Now i`m REALLY hangin for another fangin :-)
i`m trying for an entry into the Cootha Classic hillclimb in sept, so please cross all your fingers & toes for me cause my first attempt there i was running 2nd outright all day sat & 3rd outright all day sunday,,, & that was running dirt tyres :-)
so now with much lighter weight,,, new shocks,,, new springs... new slicks,,, zippy-er & tighter diff etc,,, i`m just HANGIN FOR A FANGIN :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
PostPosted: Thu Jun 18, 2015 9:22 pm
More news on the diff swap
finally got the whole lot dummy`d up into the cradle, after mucking with spacers & bushes & circlip grooves etc for the support bearings
so were really happy with clearance & sprocket alignment, so all we had to do was make a plate to mount the sprocket to the diff flange,,, got that back from machine shop today (made 2x just in case) & then all we needed was a cover of some sort to keep all that lovely oily stuff inside,,,
The last cover we used on the old diff was an orange juice tin :-)
this time i needed a slightly smaller tin to suit the salisbury diff so after a bit of mucking around looking looking looking for something laying around the shop,,, nothing seemed to be close
so i went to woolys with my vernier calipers to see if i could find maybe a can of coffee or milo or tinned apricots or something, but nothing quite right... I ended up running out of time & had to go out for dinner tonight so i cut my search off early & went & had dinner with Marlys sister & mum, but as i was feeding our puppy (George)
i realised the can of PAL puppy food was pretty close :-)
so i gave him an extra serve to finish the can off,,, gave it a wash out & started cutting her open
how`s this for aR$e--> fits like a glove :-)
Now we have a nicely sealed slippery diff, a zippier sprocket ratio (larger rear sprocket) a cradle that fits sweetly ...& an R1 yamaha powered buggy hanging for it all to be fitted into.
Soooooo,,,, guess what i`ll be doing tomorow :-) yes fitting the whole diff assembly into the buggy, bolting up the axles ,,, cutting the new X-Link Oring chain to the right length ,,, fitting the link & filling her up with go-go juice & goin for a spin :-)
Buggy is Now Zippier & Grippier :-)
cheers people
Matt
PostPosted: Fri Jun 19, 2015 5:02 pm
Who needs whizz bang cnc lathes and such when things like Pal dog food cans exist :) nice work!
PostPosted: Mon Jun 22, 2015 12:00 pm
I ran the buggy at my dads race track sunday, after a quick visit to willowbank autocross track to help/watch Gaz & Darren Duffields son race
buggy ran great , heaps more grip, heaps more zip,,, very happy, nothing went wrong, nothing broke,,, nothing fell off the car,,, except my arms,,, it`s been a while between fangs in this thing & now with the tighter diff my arms really felt it :-)
time to go back to the gym & start doing weight lifting for my arms :-)
i hope to be back on a race track shortly, so i`ll play around a bit more with a few more things & do a service on the engine & maybe change shocks n springs & wheel-aligne it etc,,, so stay tuned, i`m back on track for some fun :-)
PostPosted: Mon Jul 13, 2015 7:46 am
Pal-diff - love it Matt!! Well done sir!!
PostPosted: Sat Aug 22, 2015 1:09 pm
I have new shockys/springs package from My old mate Murray Coote, (MCA Landborough)
made specially for my buggy
just ordered full set of new Hoosier-daddy slicks :-)
can`t wait for Mt Cooth HillClimb now :-)
saturday only the 5th sept
be there or be square :-)
PostPosted: Sat Aug 22, 2015 1:50 pm
What's your thoughts Matt on the diff breakages? They're supposed to work for a much heavier car I would have thought your buggy being a featherweight would not trouble them.
Maybe the oil can centrifuges the oil away from the cones? Maybe?
PostPosted: Sat Aug 22, 2015 9:40 pm
Nice one Matt. Are Murray and Josh going to get their car done in time for World Time Attack in October? I sure hope so.
M
