It is currently Tue Jun 24, 2025 12:16 pm
Post new topic Reply to topic  [ 281 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
PostPosted: Mon Jun 10, 2013 12:39 am
f`kn-awesome Steve
PostPosted: Mon Jun 10, 2013 5:15 am
Very pretty.
Cant wait to see and hear it in action.
Dusk Blue
1964 850
PostPosted: Mon Jun 10, 2013 9:09 am
Top notch job.
Cannot wait to see how you feel once you have driven it and to hear the figures
100% Pure A Series Turbo
PostPosted: Tue Jul 30, 2013 2:17 pm
Steve
Is the wiring yours or microtech loom,, neat as.
love to hear thoughts on the mucrotech when up and running
PostPosted: Tue Jul 30, 2013 10:10 pm
nearly 2 months since the last update... don't leave us hangin'!! ;-)
PostPosted: Fri Aug 02, 2013 9:51 pm
Yeah! it's killing me. It took a month just to get the OK to bring it into the Dyno workshop. It stayed on the trailer for a week. Now it's had a parking spot on the workshop floor for a week. But, I've been promised it will be ready for the All British Day at Parramatta on the 24 August.
Dalmeny
PostPosted: Fri Aug 30, 2013 11:00 pm
Well!!! It's still not going I'm going to stick this short video up for those I have spoken to, and those that may be able to assist. Double click the pic it should go to photo bucket.
Briefly, it's running a "Microtech" ecu, original BMW throttle bodies, injectors and fuel regulator. MED crank pulley with non-adjustable pick up. Tried cam overlap from 1mm to 2.5mm lift. On advice I still have to go back and check fuel pressure at the rail and the function of the injectors.
But, it sounds like timing. The information from Microtech was to take the tooth out (36 tooth wheel) at 60 degrees before TDC, which was done by setting up a degree wheel on the crank, zeroéd it at TDC, turn the crank back (anti-clockwise) 60 degrees and the tooth under the pick up removed. Whilst trying to get this thing started information has come to hand suggesting the window on the 36 tooth wheel should be at the pick up at 90 degrees on a 4 cyclinder.
Anyhow have a listen, I'm about to throw it in a barn for someone to find in 20 years. :cry:
Dalmeny
PostPosted: Sat Aug 31, 2013 10:20 am
No sound here for some reason, but I see a backfire in 4 than 1, but you probably already know that.
PostPosted: Sat Aug 31, 2013 10:25 am
Dont give up. Thry say the tunning is the hard part.
I have the specialist performance build guide which has a little bit about timing etc. I can scan and send you the pages if that would of any help.
My the force be with you
Kiwiinwgtn
PostPosted: Sat Aug 31, 2013 11:35 am
Kiwiinwgtn
Pm sent, thanks
Dalmeny
PostPosted: Sat Aug 31, 2013 5:57 pm
http://www.extraefi.co.uk/wheel_fitting.htm
This may help you set up the trigger wheel
PostPosted: Sat Aug 31, 2013 6:01 pm
i know this may sound silly Steve,,,
but you did swap the leads over for the new firing order yeah?
& those compression figures you have are just wrong ,,, you should have about 180psi in each hole mate,,, not 100
but still should run even if it really is 100
i`m suss on your tuner fella really,,, if he can`t get an engine running then he`s not the person you want tuning it
PostPosted: Sat Aug 31, 2013 6:43 pm
I agree :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Aug 31, 2013 8:25 pm
Does the firing order change with the conversion
PostPosted: Sat Aug 31, 2013 10:24 pm
yeah... std issue minis are 1342
Twinkys are 1243
