It is currently Sat Aug 02, 2025 5:49 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jun 18, 2013 5:41 pm
Compared to a real one, it just doesn't look quite `right', does it. :cry:
Can't tell. They're all renderings by someone who's still learning the craft.
PostPosted: Tue Jun 18, 2013 7:05 pm
Theres no safety in any moke... crash in a moke and its a good chance you won't survive lol
PostPosted: Tue Jun 18, 2013 8:20 pm
Probably only slightly better than this plagerisation............
http://www.google.com.au/imgres?imgurl= ... Q&dur=3291
PostPosted: Wed Jun 19, 2013 6:56 am
Mods rock!
The new Cherry ones have a longer nose and are slightly wider than the earlier Mokes.
Paul has permission under the limited import scheme to bring 5 000 in to Oz, and under that scheme no crash testing etc is required only limited ADR compliance ;)
Dr Mini, you thinking of buying one?
PostPosted: Wed Jun 19, 2013 8:33 am
Nope! :lol:
PostPosted: Wed Jun 19, 2013 11:30 am
How much ???
PostPosted: Wed Jun 19, 2013 11:51 am
Maybe they're taking advantage of a loophole for ICVs in that though the vehicle may be new now, its based on an old design (so a replica) which helps bypass a few laws.
Other cars that use this as an example are replicas GT40s, Cobras and Caterham kits.
The red tape isn't that simple of course - but there are ways to bend the rules.
PostPosted: Wed Jun 19, 2013 11:54 am
They posted up a pic of a 16 valve four cylinder engine this morning. That could be interesting.
https://www.facebook.com/photo.php?fbid=379980552101584&set=a.264511320315175.43282.264246597008314&type=1
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jun 19, 2013 12:16 pm
That could be interesting...
PostPosted: Wed Jun 19, 2013 1:08 pm
that explains the longer nose, future mini conversion anyone if they sell the engines seprate?
PostPosted: Wed Jun 19, 2013 1:49 pm
It appears to be the same engine as in the Chery QQ. The QQ is the one that looks suspiciously like a Daewoo Matiz.
Wikipedia suggests that its the following engine:
1.1 L SQR472F DOHC 16V I4 — 50 kW (67 hp) at 6,000 rpm, 90 N·m (66 lb·ft) at 3,500 rpm
Depending on how heavy the new Choke is, it might get along OK.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Jun 19, 2013 2:00 pm
That's a very narrow cover for a twin cam :?
Would be very easy to pop a turbo & intercooler on the front of that.
If only running a few PSI of boost the stock fuel injection should manage it.
PostPosted: Wed Jun 19, 2013 2:23 pm
Does it come with air con ?
PostPosted: Wed Jun 19, 2013 4:15 pm
Lots of cars are like that now. appears to be a similar design to the suzuki m13a / m15a engine series. They're twin cams but quite skinny too.
PostPosted: Wed Jun 19, 2013 6:01 pm
micra has a tiny rocker cover aswell 16v dohc, all about making efficient power in a small car without making you feel like your sitting with your knees around your ears
